Fuel level adjustment YM-01312 tool and adapter
Discussion in 'For Sale, Trade/Swap, Wanted' started by mark1911, Apr 11, 2021.
  1. mark1911
    mark1911 Member
    liverpool uk
    Does anyone have this tool in the UK for sale or loan?
  2. Franz
  3. mark1911
    mark1911 Member
    liverpool uk
    Yes mate, I have seen it on there thought one might be a bit closer.
  4. Toomanybikes
    Tsawwassen bc
    50511F1D-4210-41F3-826B-61A66B4F30AD.png Have you checked with local dealers Yamaha, kawasaki etc these tools were in every manufacturers tool catalogue and should still be available. I have one from kawasaki that looks the same. Found a listing for it on eBay.
    mark1911 likes this.
  5. mark1911
    mark1911 Member
    liverpool uk
    I wouldn't ask dealers any where I live nearby there not the approachable type if you know what I mean! To be honest it's not the gauge or tube so much am interested in, it's the adapter that attaches to the float bowl which i can always attach a piece of tube to. The tube itself is useless without the adapter as it won't seal to the hole on the bowl unless u have the adapter or you'll have petrol everywhere, and its too expensive to buy on here and ship to the UK for what it is.
  6. mark1911
    mark1911 Member
    liverpool uk
    Not sure if the kawasaki one would fit anyway but yeah I have seen it on there.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    Do you have something like our Harbor Freight? Specializes in cheap tools. I use the black plastic fitting for bleeding brakes, fits nicely into the carb bowl for setting fuel levels.
    mark1911 and Franz like this.
  8. mark1911
    mark1911 Member
    liverpool uk
  9. mark1911
    mark1911 Member
    liverpool uk
    Managed to measure the size of the hole get it to about 2.4mm. So would I require a piece of tubing 2.4mm outer diameter? To fit snuggly in the hole to stop any leaks.
  10. XJ550H
  11. XJ550H
    chacal sells the fitting but would be costly for you
  12. mark1911
    mark1911 Member
    liverpool uk
    Yeah works out like 40-50 dollars, thanks for the post I'll try and fashion one up home made style.
  13. Simmy
    this is a simple solution I came up with.
    If you've ever bought a replacement battery (unsealed) you probably have the tubing on hand.
    Use the insulators from these closed end electric terminals to stiffen the tubing.
    mark1911, Franz and jayrodoh like this.
  14. Simmy
  15. mark1911
    mark1911 Member
    liverpool uk
    Managed to make one in the end, hope it works thanks simmy IMG_20210414_153549.jpg
  16. k-moe
    I knew I saw that somewhere. Could you do a short writeup and put it in the DYI section for me to pin?
  17. mark1911
    mark1911 Member
    liverpool uk
    Hi yeah sure I'll add it tomorrow thanks.
  18. mark1911
    mark1911 Member
    liverpool uk
    Hi,
    Sorry I posted in the wrong section like you said should of been in d.i.y.. I'll remember in future as I know you've had to move a load stuff over to the technical section from the d.i.y. Thanks
  19. XJ550H
    always nice when people think outside the box
  20. k-moe
    No worries. I moved that post and used it to start a DYI thread. I much prefer that to finding that I need to spend a weekend cleaning the DYI section up. There are still old posts from years ago that I need to weed out.
  21. k-moe
    There is no box.
