Fuel line question
Discussion in 'XJ Technical Chat' started by Niteryder, Jul 13, 2015.
  1. Niteryder
    Niteryder New Member
    Fresno, CA
    image.jpeg image.jpeg there two line coming off the petcock, one feeds fuel to the carb, where does the second one go? Is it just a vent?
    The smaller line coming of of the petcock must be hooked to a vacuum source, which is generaly the vacuum port on the #3 carb intake boot.
  3. Niteryder
    Fresno, CA
    Thank you, that made all the difference, that explains why the bike wouldn't run right when set to on or reserve.
  4. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Stumplifter likes this.
  5. k-moe
    It looks to me like it is on a short length of vacuum hose that is attached to the vacuum port.
  6. chacal
    Might be a one-way check valve (something aftermarket) that someone installed in a previous life.....
  7. Niteryder
    Fresno, CA
    Ok to leave it on or should I remove it?
  8. chacal
    If it actually is a 1-way check valve, no real harm in leaving it on (although the petcock already has a rudimentary version of the same thing internally); if it's not, then who knows? I think it would be best to ditch it, see if everything works okay, and if so, ride and be happy without it.
