Fuel tank interchange information
Discussion in 'XJ Technical Chat' started by hogfiddles, Jan 29, 2017.
Thread Status:
Not open for further replies.
  1. hogfiddles
    There are many questions on tank interchanges, so this thread is being created to address tank interchanges....from "drop-on-and-go", to "will work with modifications", to "doesn't work". Whenever possible, picture will be included so you can SEE the actual swap.
    I have already posted a lot of swap info in other threads, but I am going to try and compile it all here, so this will be an ongoing, and developing, thread.
    If you have a question regarding a particular swap, feel free to start a conversation with me.
    Dave Fox
    visitor, Steve R, Ketchup and 4 others like this.
  2. hogfiddles
    XJ650 Maxim/XJ750 Maxim
    1980-1983 all interchange.
    The 750 Maxim tank is a direct bolt-on upgrade for the 650 Maxim. Some 750 Maxim tanks have a fuel level sending unit, others do not. Either way, the 650 Maxim does not use it......just wrap it up and tuck it out of the way.
  3. hogfiddles
    XJ750rj tank on XJ650rj non-turbo
    the '81-'83 xj750r tank will fit the '82-'83 650rj non-turbo Seca.
    The front of the tank will interfere with the horn assembly. Relocating that assembly will alleviate that issue.
    The rear of the tank does not line up perfectly with the seat and side cover, so you would need to find a creative way to disguise the strange intersect of the 'lines'.
    In the USA, this is the XJ650 Seca. in Europe, it is simply the XJ650 since they did not get the Maxim styling.
    Ezekiel Gavieres likes this.
  4. hogfiddles
    XJ750 Maxim tank on an XJ650rj non-turbo
    Up-to-1983 XJ750 Maxim tank will physically fit on the 1982-1983 XJ650r
    Issues:
    -Tank bumps up against the horn bracket, relocating the mount would solve that
    -the overal tank cavity is shorter in length, so there is a major gap between the seat and the tank
    -The tail end of the tank is narrower than the 650r tank, so it does not flow into the covers, seat, etc.....
  5. hogfiddles
    1982 XJ550r on a 1982 XJ750r
    Ok so-- the 550r tank will just barely fit on a bare 750r frame, but is not a drop-on fit, for a complete bike. It's close enough to almost fit, but here are the problems:
    Trailing end of the tank doesn't 'flow' into the side covers.
    AND
    Side cover top mount has no hole to go into so the cover is loose. The 750r tank has a hole and bushing for this mounting post
    The tank mount rubbers are too thick, ad the tank can't slide into place.
    Removing the tank mount rubbers allows the tank to slide into the mount position, but then there's no isolation, and the tank rattles around them.
    BUT
    With the tank just sitting in this position...... Thee front of the tank interferes with the handlebar cover. Removing the cover will alleviate that issue.
    BUT
    The front of the tank interferes with the reflector mounts. If these are removed, that will alleviate that. I DON'T think it will move the tank forward enough to cause any more interference with the handlebars though force the handlebar cover is removed. It feels like there's enough space under the cover to avoid that issue again.
    BUT
    Unless the reflector bases are removed, the tank can not slide up the last centimeter, or so, to allow the rear of the tank to line up with the rear tank mount. HOWEVER, if they are removed and the tank is pushed as far forward as it go, then the tail can be finessed onto the rear mount.........the issue then is that the tank mount bushings at the front can't fit all the in anyway because the bushing cups on the tank itself are jammed tight up against the bushing mounts
    PLUS
    The rear of the tank is still elevated above the rear mount because the bottom of the tank is too flat near the end of the tank and it hits the frame before the tank is sitting down on the the mount. A good rubber spacer could be made for that........
  6. hogfiddles
    1983 XJ900rk/1984 XJ750rl
    These tanks are direct swaps for each other.
    Issues
    -none
    -only differences in tanks will be that some had hooks for the air scoops, and some did not.
    The bikes are basically the same bike. The major difference is that basically the 750rl is a 900rk but with a 750 engine. Virtually every other part is the same as the 900 with few differences.
    No picture is needed.
    Simmy likes this.
  7. hogfiddles
    In the meantime, here's some general info minus pics. As I can take pics, I'll move the write-ups to individual posts as above...
    Pulling together info that I have posted regarding tanks..... sometime I'll even re-write it to make a it a little more coherent and logical. Nonetheless, here's the info. Read through it, and maybe you'll find what you need:
    Just for giggles, I did swap some things around to see how things fit:
    1 900rk Tank- does NOT mount onto the xj650 maxim, xj750 maxim, OR xj750 seca frame. The upper mount for the frame reflector contacts the seam edge of the 900 tank before the tank can slide onto the rubber mounts. If the reflector mounts were cut off, the tank would slide onto the rubber mounts, BUT the tail of the tank would still be about an inch too far back and will still not allow the tank to be bolted down.
    2.750 Maxim tank - as we all know, the 750 maxim tank is a direct bolt-on swap for the 650 maxim tank. The 750 maxim tank WILL also bolt directly onto the 750 seca frame without any modification to the tank of the frame.
    The seca seat will still work on the frame, but there is about a 1" or so gap between the seat and the 750 maxim tank.
    The seca side covers will not mount onto the frame as the tail end of the maxim tank aims down at the back and interferes with the sidecover top-front edge.
    3. 750 seca tank - WILL physically bolt directly onto the 650 and 750 Maxim frames.
    The Maxim seat front edges need to be modified to fit the extra length and steeper angle at the rear of the 750 seca tank.
    I did not have time to check on sidecover fit. However, due to the upsweep at the rear of the seca tank, the maxim side cover upper front point should still be ok and not interfere.
    Regarding 650 Seca / 650 maxim
    Frames are different, I haven't done a seat-swap comparo, but I have done tank-swap comparo which is here in another forum......
    That all said, if I get the time in the next few days, I'll try to do that for you.
    In the meantime, a quick solution would be to pull the covers and foam, and the do a Seatpan swap..... The seat mounting is different
    The 650 rj tank will fit the maxim frame, but you should use the 650rj triple clamps to allow clearance at the front if the tank.... Otherwise you'll run the fork tubes up against the tank on tight turns
    650rj tank on a 550r
    650rj tank is slightly shorter in length, by about 1/4 inch at rear oval mounting hole. However, if the tank is pulled back just that tiny bit it will bolt into place. Doing that though, pulls the front hooks about 1/4" back, which leaves a slightly "loose" fit at the front.
    The petcock just clears the valve cover but with enough clearance to not be an issue.
    The bottom rear of the tank does interfere with the seat pan's lower front corners but they could be trimmed back and re-shaped a bit to allow the seat token and close again.
    The front of the seat is too long, too, but if it is cut back and re-shaped and re-curved I could be made to fit nicely.
    All that would be cosmetic changes, and readily do-able.
    The only "major" issue will be that the bottom of the cramped edge of the tank touches the top ends of the airbox. Once the tank is bolted down there will be pressure in the airbox. If the airbox is heated and softened, the two "channels" could be formed. I guess the tank could be trimmed, but I think that may weaken the seams and I wouldn't recommend that.
    550r tank on the 650rj
    The 550r tank is about1/4" too long, PLUS the front mounting grommets are just a little bit too wide for the tank to slide on.
    When the grommets were removed the tank almost fits right in place.
    However, the lower front edges of the tank interfered with the horns. If those are lowered or relocated, that issue will be easily resolved.
    The rear of the tank tunnel interferes with the frame but if the tank rear is raised about an inch or so, it clears the frame. If some makes a riser/spacer to mount the tank just that little bit higher its right in line above the regular rear mount
    The issues to really address would be --what to do about the tank grommets on the 650r, and the rear mount. Here are the solutions....
    Two things must be done for the front:
    1. The big ring on the mount needs to be moved in toward the backbone about 1/4" on each mount to allow the rubber grommets to fit in the slightly narrower tunnel of the tank.
    2. Use the grommets from the 550r, as they are slightly less tall AND the have a little bit smaller diameter that the 650rj grommets.
    For the rear of the tank--make spacer to mount the end of the tank about an inch or so higher above the original mount.
    Long and short of it:
    Either tank can fit on either bike with either seat mods and airbox mods to put a 650r tank on a 550r; or, minor alteration to the front tank mounts on the 650r, relocate the horns, and add a riser for the rear mount will allow the 550r tank to fit on the 650r
    Dave Fox
  8. hogfiddles
    XJ1100 tank on an XJ750 Maxim/XJ750 Maxim tank on an XJ1100
    I have had a few inquiries regarding whether an xj1100 tank could be an upgrade to the 750.....Sad to say, it is not. The 1100 tank is MUCH bigger, and the tunnel is much WIDER. If you have a lot of money, and want to do a lot of custom work, I guess you could make something happen, but it's definitely not a drop-in swap. Also, the plumbing for the Xj 1100 tank would be different.....there are two petcocks to contend with.
    It would NOT be an upgrade to try and put a 750 tank on the 1100, either. First, it won't fit because the tunnel is too small; second, the 750 tank is way too short; third, you'd have LESS fuel capacity.
    From the start, you can see a substantial difference.........Xj 750 Maxim tank on the left, Xj 1100 tank on the right
    A peek underneath....again, xj750 Maxim tank on the left, xj1100 tank on the right.
    Wintersdark likes this.
  9. hogfiddles
    XJ750rj tank on 1983 XJ650 Maxim
    The 750r tank will physically bolt right onto the 650 Maxim frame. But, while it will physically fit right on, there is a little work tat will need to be done.
    The seat is slightly too long in the front. Specifically, the 'rise' at the front of the seat is too far to the front to allow it to drop back into place. The seat will fit into the area if you take some time to address it. The front of the seat will need to be trimmed back, the pan will need to be reshapced a bit to work around the tail of the 750r tank. My recommendation is;
    1. take the seat cover and the foam completely off
    2. install the seat pan into position and lock it in place. Trim the front lip as needed.
    3. set the foam on top of the pan, as close to in place as you can get it.
    4. Take your time and slowly trim the foam back and shape it as needed
    5. Re-staple the cover
    You will need to get creative if you wish to cover the funny-looking areas where the tank/cover/seat meet.
    The tank clears the triple clamp and handlebars
    The side reflectors clear the tank by about 1/8"
    1983 XJ650 Maxim w/750 maxim tank
    XJ650 Maxim w/750r tank
    Sits perfectly on rear mount, but raises the top line of the tank to interfere with SEAT FOAM.
    Perfect fit on front mounts
    Clears triple clamp/bars/forks
    Clears side reflectors, easily - but not by much.
    Dave in Ireland likes this.
  10. hogfiddles
    XJ750rj tank on an XJ900rk(XJ750rl)
    The tank physically is close, but would take extra work to make it half decent.
    There is a big gap at the front of the tank
    The seat physically fits, but would have to have the plastic pan re-shaped at the front. Heat the plastic and bend it out....
    The rear corners of the tank, the side covers, and the seat do not meet well at all.
    The rear of the tank is awful close to meeting the mounting point, but is about an inch or so shy, and even with the rubber cushion removed, the tank does not sit down on it. The tank is slightly to narrow.... I'm sure some careful hammer-work would solve that. The other issue is that the wire pigtail from the sending unit is right where the frame wantsto be, and it pushes the tank a bit to the left. When things are removed, and the tank is pulled back far enough to sit on the boss, the tank still does not clear the frame, and the front mounts are just about off of the rubber cushions there.
    So, the long and short is that it's close enough to be possible with some extra thought and work. But, it is not a drop-in replacement or upgrade.
    Franz and Steve R like this.
  11. hogfiddles
    xj650rj tank on xj750 maxim
    the xj650rj tank physically fits and bolts down. I was not able to check fork clearance lock to lock at this time. With this tank in place, the seat does not have enough clearance so modification to one or bit ends of the seat to get it short enough to fit.
    tank bolted down—seat just a bit too long for space
    looks like plenty of room, but the forks are turned a bit. I would suspect that a different triple clamp would be needed to ouch the forks forward a bit. If the fork diameters are the same, I’d think that the 650rj clamp should be used, like I expect for the 650 maxim, as I also said way above.
    rear mount bolted down
    Tank on without seat
  12. hogfiddles
    xj650rj tank on xj650 maxim
    see comment way above, regarding forks and triple clamp.... but here is a 650rj tank bolted onto a 650 maxim frame. I expect there would need to be some modifications.
  13. hogfiddles
    xj650rj tank on xj900rk (and 750rl)
    some requests for the following possibility yield these results:
    first thing a pic of the test mule.... a mistreated 900rk awaiting resurrection.
    Now, a 650rj tank is on it....lets see—
    Ok, it does look close enough to warrant a closer look. First thing that stand out is that there is no place for the side cover “bullet” to mount to anything. The 900rk tank is wider and the mounting point on the tank is lower than the back of the 650rj tank. The 900rk seat pan locks in place, but the 650rj tank is not as tall, and the Rear angle is steeper. The seat base is plastic so it MAY be possible to re-shape it enough.
    The tank is all the way forward, fully seated on the front tank mounts. There is interference....
    At the fork cover at left and right full lock ( it’s plastic, and removable....... could be modified or removed)
    At the crown
    At the crown and right control ...(handlebars can be repositioned since they are adjustable)
    The rear tank mount is just a little too far forward from the tank mount boss. Also, the 900rk rubber is too wide.
    With a couple adjustments, we get this:
    The rear tank rubber mount has been replaced with the rubber mount for the 650rj tank. THAT is a perfect drop-on fit onto the frame ( and obviously it will fit the tank it came with)....but will it actually work? The tank has been pulled back enough to seat on the rubber. BUT—- the tank can’t sit all the way down as it now interferes with the frame somewhere
    In the tunnel. A thin piece of rubber to eliminate metal to metal contact PLUS a spacer/riser of some sort just long enough to eliminate tank movement, AND a longer mounting bolt might work.
    Pulling the tank back relieves interference at the front at all points previously discussed, EXCEPT for the right hand control..... all shown in the following views.
    Finally, by pulling the tank back for the rear mount to line up, the front mounts are now only about half way on. Some homemade mounts, or modified factory mounts that would be ovals with off-set holes may work.
    my opinion is that it is a do-able option if you are willing to do some customized work, but it’ll take a bit to make it LOOK good, too.
    It is not a drop-in replacement. But hey—go ahead and try it and push the envelope a bit since now you know what issues to address!
    ( Also my opinion..... I think this kind of swap looks incredibly ugly..... but the purpose of this forum is to show possibilities and/or futilities, my opinion is just my opinion)
  14. hogfiddles
    xj550 maxim tank vs. xj550 seca tank
    The 550 tanks are close enough to swap WITH some fabrication, but they are NOT drop-in swaps. Follow along—
    xj550r tank on an xj550 maxim
    It is close. What needs to be done:
    1. The rubber grommets at the front are tight. With extra pressure/pushing/wiggling, the tank slides on. A dab of grease will help, and aid in preventing the tank from sticking to the rubber over time. Not a big issue.
    The tank will butt up against the reflectors. I removed the reflectors but the tank did not slide any farther forward.
    2. THE BIG ISSUE - the rear of the tank over-shoots the rear mount by approximately the width of the mount. The original mount boss does not interfere with the tank. I did not re-install the bolt.
    -An extension could be fabricated. The original mount can be ground off, the bolt hole drilled through and tapped so an extension with a mounting boss cut off of another damaged frame could be bolted on for a secure tank mount.
    I did not have a seat available..... my guess is tha the front of the seat would need to be shortened accordingly.
    tank is against reflectors
    Rear of tank is too long
    Looking in through the rear tank mount hole
    xj550 maxim tank on an xj550r
    The xj550 maxim tank is conversely a little shorter than the xj550r tank.
    Front mounts - it slide right into place.
    The issue -
    1. The rear of the tank does not reach the mounting boss. So, either an extension forward is needed.....
    or—
    2. move the tank back.... BUT, when that is done, the front mounting cups on the tank do not reach the mounts, so either THEY would need to be moved, or two extensions would be needed to move them rearward.
    The xj550 maxim tank is too short when mounted on the front rubber grommets
    The xj550 maxim tank cups don’t reach the rubber grommets if the rear mount of the tank is on the rear mount boss
    Verdict; Do-able, yes. Drop-in swaps, no. Fabrication required.
    Minimutly and chacal like this.
  15. hogfiddles
    XJ650 Maxim tank on XJ550 Maxim
    The XJ650 Maxim tank CAN fit on the XJ550 with some careful modification. The tanks are the same capacity but the shapes are slightly different. The 650 tank is also a little longer.
    Differences:
    - 650 tank is somewhat more pointed, 550 tank is somewhat more blunt.
    - 650 tank is slightly longer
    - 550 tank has slightly wider ‘shoulders’
    - 550 tank tunnel is slightly narrower. The 650 tank will sit comfortably on the front rubber tank mounts on the 550 frame, but the 550 tank will not fit onto the front rubber tank mounts on the 650.
    Modification -
    The only thing necessary, other than care and skill, is to detach the two ‘cups’ on the underside of the 650 tank and relocate the back about half an inch or so. Place your 650 tank on the 550, and measure the exact distance that the tank need to move forward so that the rear of the tank will center itself on the rear rubber mount.
    XJ550 Maxim tank
    XJ650Maxim tank
    XJ650 Maxim tank rear mount is too far back
    Front is slightly pointier, but has room to move forward
    XJ550 Maxim tank on left, XJ650 Maxim on right
    XJ550 Maxim tank on bottom, XJ650 on top
    Verdict: This swap will work with modification of moving the XJ650 tank’s cups back about half an inch or so.... I haven’t done it, but I do know a fellow from a previous Central New York Carb Clinic who did do that.
Thread Status:
