Fuel tap
Discussion in 'XJ Technical Chat' started by Maddog, Sep 2, 2023.
  1. Maddog
    Maddog New Member
    Uk
    Hi
    Thanks for acceptance
    short_circutz likes this.
  2. Maddog
    Maddog New Member
    Uk
    Hi
    I had some trouble to post the above thread
    Is anybody able please to identify for me the vacuum tap in the previous photos
    And which rebuild kit I would need before I fit it on my RD350LC
    many thanks in advance Al
  3. short_circutz
    short_circutz Active Member
    Sault Ste Maire, On, Canada
  4. Timbox
    Timbox Well-Known Member
    Welcome to the forum. I think you are looking for a vacuum line that will run to the carbs for that one. That allows your fuel to flow when the engine is running. As the motor turns over and the carbs start to do their jobs, that line have vacuum on it. That allow the diaphragm inside the petcock to open up and fuel to run to the carbs.
    There might be a "Prime" setting on the petcock as well, this will allow you to bypass the vacuum portion of the petcock and should be used first if you cleaned your carbs and they are dry.
