fuel/ vac line configuration
Discussion in 'Hangout Lounge' started by warchol2, Mar 22, 2012.
  1. warchol2
    warchol2 Member
    st.clair MI
    could someone tell me what lines go where? i have 3 lines and only 2 spots on the petcock because the PO had a non yamaha tank with 2 vac lines on it
    so do i just cap off one off the vac lines? i couldnt find anything in my manual
  2. bigfitz52
    The stock Yamaha configuration for your bike is one fuel line, from the petcock to the carbs (the big fitting;) and one vacuum line, from the vacuum spigot on the #3 intake manifold to the small port on the petcock.
    The other three vacuum ports on the intake manifolds remain capped except for when you vacuum sync the carbs.
    Take a look through the petcock rebuild article; even if your petcock is fine there's a lot of other valuable info in here: http://xjbikes.com/Forums/viewtopic/t=25058.html
  3. warchol2
    warchol2 Member
    st.clair MI
    okay thanks alot thats how i have it now. i just need to cap the #1 intake then, how would i got about dooing that if i dont have those litttle oem caps?
    and thanks for the link ill check that out
  4. bigfitz52
    you get some little OEM caps w/clamps from XJ4Ever; or you go to the nearest auto parts store with an existing cap in hand and match it. And use a tight zip-tie as a temporary clamp until you get some real ones.
  5. warchol2
    warchol2 Member
    st.clair MI
    awsome thanks for the help
