Fuse box question
Discussion in 'Hangout Lounge' started by manofchange11, Apr 13, 2012.
  1. manofchange11
    manofchange11 Member
    I changed my battery and now my blinkers, headlights, and gauge display now work intermittantly.....really frustrating as this has never happened before since the five years I've had the bike. After I change out my weak old battery the problem happens.
    Through more work I found out the problem is in the fusebox...any ideas on how to fix this?...replace fuse box?
    Thanks.
  2. hogfiddles
    Re: Good Mechanic in the Minneapolis, MN diagnose electrical?
    Check the condition of the fuse box and the clips. If they are getting soft and weak, this can happen.
    Dave F
  3. manofchange11
    Thanks...I just actually found this out!!! When I messed with the fuse box...I was able to get the lights to go back on. Then I sanded the clips and one of them broke off! Is it hard to install a new fuse box?
    Thank you.
  4. wwj750
    wwj750 Member
    central minnesota
    You should replace the glass type fuse holder with a blade type holder. These bikes are notorious for fuse related problems. Go to XJ4 ever at the top and order one from Chacal. Very easy to do & solves a lots of problems.
  5. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Check out my electrical post in my signature to see how easy it can be to replace the fuse panel. :)
    I just got carried away taping up the new wires to look like the original wiring harness.
  6. Ross1
    Ross1 Member
    Syracuse,NY
    I promise...XJ4EVER
    Get the 6 blade model fusebox,and if you have the cash,get the pre-wired extension kit also
    The info sheet was worth the price
