Fuses...
Discussion in 'XJ Technical Chat' started by BadSSBowtie, Jul 8, 2011.
  1. BadSSBowtie
    BadSSBowtie New Member
    Hey guys... So i am going over my bike fixing a bunch of stuff that the previous owner kinda screwed up. I wanted to redo my fuses. I bought Blade-Style fuce holders with protective caps. The only thing I am not sure of is what size fuses should be in them?!?! If you guys could let me know, that would be great!!! Thank you!!!
  2. bigfitz52
    What bike?
  3. BadSSBowtie
    Oh I am sorry.. Its a 82 XJ550.
  4. pbthoe
    pbthoe Member
    Moore, S.C.
    Not sure on the 550's but on 650 it is 20 amp for the main, and 10 amps for everything else. You will not regret updating fuse block.
  5. bigfitz52
    OKAY. Add that (and other pertinent bike info) to your sig, please.
    Stock fuses in the 550 are MAIN: 20A; all the rest are 10A.
    You can rebuild the stock fusebox if you want to retain the original appearance and put up with glass fuses;
    or you can replace it as you're suggesting. On the 550, you'll need to "notch" the arm on the tool tray slightly and attach the new fusebox to the top of the airbox.
    Check with XJ4Ever for a fusebox retrofit kit that will work with a minimum of fuss.
