FZR600 Front End on Seca2 - with Pics!
Discussion in 'XJ Modifications' started by XJ600S, Aug 15, 2008.
  1. XJ600S
    XJ600S Member
    Boulder, CO
    So after laboriously trying to track down all the parts necessary, I finally succeeded in gathering the proper parts, minus a front fender. Thats mainly because I can't decide if I want to do a FZR600 stock fender, or upgrade to the 1998 R1 front fender (swoops down and wraps around forks for a sleeker look).
    Parts:
    2003 Yamaha R1 Front Brake System (Calipers, master cylinder, lever)
    Two SB8125L Speed Bleeders for R1 Brake System
    1997 Yamaha FZR600 Front Wheel / axle / rotors
    1994 Yamaha FZR600 Front Triple Trees
    1998 Yamaha FZR600 Front Forks
    1998 Yamaha FZR600 Fork Brace
    8 oz Jug of Belray Dot 4 Brake Fluid
    16 oz Can of Belray Brake and Parts Cleaner
    As far as front brake system, I opted for the R1 calipers since they have the gold star covers over the calipers. The R6 ones will work just as well, only they have a blue star cover. But when you buy these...ENSURE...I repeast...ENSURE they are not the radial mount calipers. They have to be pre-2003 calipers and mount like mine look.
    Injuries Resulting from Swap:
    Massive/Deep cut on Palm of right hand from breaking a 6mm hex wrench. Apparently, that one bolt was so cross threaded, I ended up just cutting it off.
    Process:
    I woke up early at 5am to beat the heat. I started wrenching at 5:30am after I moved everything I needed out to the street. Basically, it went like this:
    -Remove front wheel
    -Remove front forks
    -Remove headlight / headlight tabs / clip-on bars and set aside.
    -Remove upper triple clamp
    -Install FZR600 front forks
    -Install FZR600 front wheel
    -Install R1 calipers
    -Align everything up, and torque to specs, ensuring all throttle/brake/other cables are not interfering with each other
    -Install Speed Bleeders
    -Figure out Speed Bleeders
    -Get mad, strain back too much, and go lay down in grass for 10min
    -Think through the process, and retry
    -Speed Bleeders installed, time to start bleeding left side
    -Bleed left side until tiny bubbles are coming out of speed bleeder
    -Bleed right side until tiny bubbles are coming out of speed bleeder
    -Repeat left and right sides until clear, bubble free fluid comes out
    -Top off brake fluid and toss out old/new fluid
    Take it for a test ride, check the brakes, making sure everything clears, and then take pictures! I am trying to figure out where to mount the front master cylinder, but I figure I've got a little while to figure that out. The MC is full of fluid and is mounted in such a way that it won't get any air sucked into the lines if it tilts down a bit (but is not actually bolted to anything yet).
    I am still trying to figure out how I want to mount the instrument cluster, and if I want to bring back my front double bubble fairing. I liked the look of it, but for some reason, without the screen, the bike looks a lot more appealing to me.
    I finished the project up around 11am, with a single 30 minute trip to the hardware store. So in total, around a 5.5 hour project...but worth every minute and seemed to only take 2 hours since I started so early!
    Here's a few pics:
    Results:
    I have to say, I can definitely tell a major increase in braking power. In fact, its so much that I have to adjust the lever so it is closer to my hand so I don't over squeeze. I don't want to do an endo when I'm only trying to stop at a red light.
    I need to swap my brand new front tire from my old rim to the new rim. The tires are the exact same size, but once I need a new front tire, I will upsize to a 120, so it will be easier/cheaper to replace.
    I plan sometime this winter on purchasing stainless steel brake lines for both front and rear and install them. I have to say though, that after installing the speed bleeders, I will never, NEVER pay someone to bleed my brakes again. They are amazingly easy to use, and its pretty self-explanatory as well. On top of that, they are only $7 a piece!
  2. spinalator
    spinalator Member
    Regina, CANADA
    Very cool upgrade!
  3. eflat7
    eflat7 Member
    I am in love with that bike. I wish I could find a cheap Seca around. I will probably end up getting one soon.
