Gas tank capacity on 1982 XJ750RJ
Discussion in 'XJ Technical Chat' started by HeckticHaze, May 20, 2012.
  1. HeckticHaze
    HeckticHaze Member
    Upstate New York
    I was riding today and had to use the reserve on my gas tank for the first time. I know the tank holds 5 gallons of fuel. Does anyone know how much fuel the reserve tank holds and when the red warning light starts flashing how much fuel is left in the reserve?
    Thanks.
  2. KrS14
    KrS14 Active Member
    St Marys, Ontario
  3. HeckticHaze
    HeckticHaze Member
    Upstate New York
    KrS14, thanks for the information. I did find a spec in the Haynes manual that said the reserve was 1.1 US gallons. I looked in my original owners manual and it just states that when the red warning light starts to flash it is a low fuel warning but it does not specify how much fuel is left. The thread you did give me had some good info from other riders.
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    My 750 Maxim has to switch to reserve before the low fuel warning light starts blinking. I think the sender needs adjustment. I have one bar left when it starts to run out of gas. Flip it over and about ten more miles the light starts to blink. And if I don't get gas soon after , she runs out and it's a walk to the station.
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Mine behaves the same way MN, sputter, turn to reserve, then a bit down the road FUEL comes on. Kinda ass backwards lol
  6. Durk
    Durk Member
    Pittsburgh, Pa
    I have to switch to reserve a little ways after I go down to 1 bar on the fuel gauge. There are 4 bars on the gauge for 5 gallons, so 5/4 = 1.25.
    So you could assume for every bar gone you've used 1.25 gallons of gas, so when you have 1 bar left you've used 3.75 gallons (3 x 1.25), leaving you 1.25 (5-3.75), which is in the ballpark of the 1.1 reserve capacity.
