gaskets
Discussion in 'XJ Technical Chat' started by seanvfr, May 20, 2009.
  1. seanvfr
    seanvfr New Member
    Ireland, Waterford
    :?: im rebuilding my xj650 engine, my ? is, do i use gasket sealer on my new cam cover gasket or will it seal good enough on its own, Irish XJ owner & lover, thanks in advance .
  2. bigfitz52
    "glue" it to the cover with sealer, and smear silicone grease or similar on the down side. Then you should be able to re-use the gasket the next time you pull the cover.
