General carburator question
Discussion in 'Other Motorcycles' started by clhannah, Jun 27, 2009.
  1. clhannah
    clhannah Member
    Portland, OR
    Hey guys --
    The sweetie's learner bike is a 150 scooter based on the GY6 with a Keihin style CV carb.
    pics here
    http://www.scooterfocus.com/scooter_car ... tment.html
    The second pic shows a vent pipe pointing down, just to the left of the automatic choke. This is where fuel is pouring out.
    A: the vacuum petcock works
    B: good strong spark
    C: if I drain the carb and disco the petcock, I can eventually get the engine to run. It staggers and smokes, then runs clean until dry.
    D: if I reconnect the fuel it pours out the vent and the engine stalls.
    Q: is this a stuck float valve?
    Thanks!
  2. RickCoMatic
    Sounds like you have already proved that.
    Tap ... LIGHTLY <--- on the Fuel Bowl with the Butt-end of a Hammer or the Plastic Handle of a Screwdriver.
  3. clhannah
    clhannah Member
    Portland, OR
    Rick U are awesome!
  4. clhannah
    clhannah Member
    Portland, OR
    It only took a coupla hours to strip the plastics, pull the carb, pop the bowl, and get it all back together again. Very sweet.
    The float valve core piece was a silver metal, whereas the body was brass. The core had some corrosion -- black pitting, as well as a white crystalline build-up. It was the latter causing it to get stuck, and it cleaned up with a nail board. I am hoping the crystal deposits were a matter of poor storage and will not recur.
    Thanks again! The sooner she gets confident on the scooter, the sooner she can transfer to her xj550!
