General Help Getting The Old Girl Going. 1983 XJ750
Discussion in 'XJ Technical Chat' started by XBeatzX, Jul 11, 2011.
  1. XBeatzX
    XBeatzX New Member
    Hello all, Just wanted to say thanks to everyone who contributes to this forum, I have been lurking the last couple of months, and happily surprised with the love for these model bikes. I picked up a 1983 XJ750 the day I turned 16 in '91 with 800 miles on it and rode it on and off throughout the 90's until I got married and had kids and the wife said no more, too dangerous. Well I got rid of the wife, and pulled the ol' XJ out of storage last week and am ready to get it going again. It's been sitting for nearly 10 years. Was hoping I could just put up a few questions now on then on this post and any help would be appreciated.
    The first thing I did was pulled the carbs this weekend, gave them a good boil, and cleaned them up pretty good. The float needles were the dirtiest and stickiest of everything, and it went fairly well. It certainly was a grueling job, but glad I did it myself, learned allot. besides wishing I had been a little gentler with the brass bits, and for the life of me not being able to get this light film off the bowls it went well. Tonight going to flush the tank with diesel fuel and some nuts and shake the hell out of it, but the tank looks pretty good. then change the plugs and all the fluids and recharge the air filter.
    My main question is this at this point. My plug wires look strange and in the wrong order to me, though I may be wrong. From the position of sitting on the bike, the labeled plug wires are in this order. #1 is on the far left cylinder, #2 is connected to the inner left cylinder, #3 is connected to the far right cylinder and #4 to the right inner cylinder. #1/#4 coming out of the left coil, #2/#3 coming off the right coil. Does that sound rite?
    Also, I know my back tire needs replacing, but my front one has maybe 100 miles on it, but has been sitting for 10 years, is that tire safe, or should I replace it. I don't see any cracking and it was always stored inside. Anyway, thanks everyone in advance for your help, and I will try and pay it forward.
  2. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    1 check back brakes for delamination
    2 toss that old rubber away (dry rot)
    3 ASAP and/or when can afford replace front brake lines, rebuild master cylinder and obviously bleed system
    Others will chime in with other crucial items to do to your dust collector err been sitting bike :)
  3. Metabolic
    Metabolic Member
    Atlanta, GA
    I will heartily second the brake admonitions listed above and tossing the old tires. Not worth the risk.
    If it's been sitting awhile you might want to top off the oil and see if there are any leaks - seals and gaskets have to be pretty old. I'd also recommend digging back in the engine crannies and making sure there isn't any detritus lurking back in there . . . first time I rode my "barn rescue" Maxim a large clump of oil/gasoline soaked leaves made the bike catch fire underneath me, leading to consternation.
    I'd also tell you to get a new battery, hook it up, then take a wooden dowel and poke at the wires throughout the bike's frame (gently) with the headlights/signals going. You might find out about some electrical gremlins/exposed wires before discovering this on the road.
    It's a great bike, definitely worth the effort.
  4. pirok
    pirok Member
    Aarhus, Denmark
    The cylinder numbers are 1,2,3,4.
    #1 is to the far left and #4 is to the far right. So just follow the numbers on the labels, which means that you should switch #3 and #4 if i understand you right.
  5. XBeatzX
    XBeatzX New Member
    That's what I thought. They must have gotten switched at some point in storage, maybe even ran that way for awhile because I noticed when cleaning the carbs that #4 carb was twice as dirty as the other three, not sure if that would cause that or not though.
  6. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    My bike has 1/4 on left coil and 2/3 on re right.... which is correct per factory manual.....
  7. XBeatzX
    XBeatzX New Member
    Thanks guys, that really helps. Anything special I should do with the petcock? I have it off to clean the tank, and planned on just rinsing it out good with diesel fuel. And now that I look at it, what setting should it be when running.
  8. jmilliken
    Dillsburg, PA
    Oh yea.... to answer the rest of your question
    Compression test
    check frame for rust/failure
    Factory manual
    Chuck the tires
    replace rear brake
    rebuild mc + front brakes
    New plugs
    new fuse box
    New battery
    check electrical for hidden gremblins as suggested above
    valve shim clearances
    Clean carbs + replace rubber (search for "the whole nine yards"and "in the church of clean")
    throttle shaft seals
    This is just a basic list.... if anyting else looks suspect ... id just replace it
  9. Metal_Bob
    Bourbonnais, IL
    Replace the petcock to tank gasket since you took petcock off...
    Consider upgrading original fuse panel before attacking any electrical gremlins.
  10. XBeatzX
    XBeatzX New Member
    Uh oh. Just changed the oil, and I could tell rite away it was way to water like and far too much of it. Looks like atleast a couple of quarts of gas was in the engine. Any ideas what would cause that? Gas getting past the petcock or something from sitting? Looked clean though with no metal bits.
  11. SQLGuy
    SQLGuy Well-Known Member
    Two problems:
    1. Petcock is probably not shutting off properly when vacuum is removed (engine is stopped).
    And
    2. (The main issue) Float levels incorrectly set, or, more likely, one or more float needles not sealing properly.
