Got Pods? Get Race Carbs! Race Carbs on Sale!
Discussion in 'XJ Modifications' started by RickCoMatic, Jun 15, 2008.
  1. RickCoMatic
  2. Zookie400
    Zookie400 Active Member
    Connecticut
    that is an excellent price.......very tunable carbs!
  3. Anthony14
    Anthony14 Member
    Mississauga, Ontario
    Wow, I thought it said 87 bucks lol.
  4. Deathmetaldan
    Deathmetaldan Member
    Sunbury PA 17801
  5. cheffrank_357
    cheffrank_357 New Member
    ft. lauderdale, florida
    i saw these
    i thought about getting them
    is it a bolt on application? do they work right out of the gate?
  6. Zookie400
    Connecticut
    i would venture to say HELL NO! jetting depends on engine size, exhaust, and a number of other possible variables so i doubt they will be perfect. they might start run and sputter for you though.
  7. SyracuseXJ
    SyracuseXJ Member
    Wilmington, NC
    Wow, didn't pay that much for the bike...
  8. Zookie400
    Connecticut
  9. applexj
    applexj New Member
    "Smoothbore slide carbs make more top end (and sometimes midrange and upper midrange) HP, by way of flowing more air than CV carbs for a given diameter. When the throttle is all the way open, there is nothing obstructing the flow of air save the jet needle, unlike a CV carb, where the butterfly shaft and, depending on rpm, the slide is in the way. The smoothbore carb also has no turbulence-causing divots in the wall and floor of the bore for the slide to fit in. Instead, the slide is a much larger diameter than normal, allowing it to intersect the wall through two slits. The disadvantage is that the carb cannot easily be tuned to work well at all rpm for a given throttle position, if at all. This means that the rider must learn throttle control, i.e. cannot expect to be able to whack the throttle all the way open from idle or just off idle and expect the engine to pull cleanly."
    - Derek, Motolab
  10. yamyboy
    yamyboy Member
    Toronto Ont Canada
    Rick I PM you and you couldn't tell me this LOL. This may be the awsner I needed. It look like I cam play with other thing and still be able to toon them. Good eye thanks.
  11. chacal
    Chef-Frank, the carbs on Turbo models has some special features to seal them against the boost pressure, which means that you're pretty much going to be using the factory carbs!
