Green plug inside headlight??
Discussion in 'XJ Technical Chat' started by sab282, May 9, 2012.
  1. sab282
    sab282 New Member
    I just took my headlight out and there is a green two wire plug with black & black/yellow wire. The wires are looped together?? What is this plug?
  2. midnightmoose
    midnightmoose Member
    York, PA
    Its for your clutch switch which is a safety feature that requires you to pull in the clutch to start the bike.
  3. sab282
    sab282 New Member
    So someone has just bypassed it by looping it??
  4. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Correct.
    I bet it looks like this one did
  5. bigfitz52
    When it's IN GEAR (and as long as the sidestand is up.)
    Clutch switch 411: http://xjbikes.com/Forums/viewtopic/t=30354.html the switch itself mounts in the clutch lever perch.
  6. boostenlebaron
    boostenlebaron Member
    Sturbridge MA.
    Just unplug it instead of grounding it together. It doesnt need to be that way and its a touch safer. You just can only start it in neutral. With it ground together you can start it any time.
  7. sab282
    sab282 New Member
    tskaz
    Yep thats what it looks like. I was just making sure.
    boostenlebaron
    I can really just unplug it??
  8. tskaz
    tskaz Active Member
    It's a catch 22.
    If you have it jumpered like it is, then you can start the bike in gear with the clutch out, as long as the sidestand is up (if the sidestand switch is working).
    If you unplug it, you can only start it in neutral, which can be a pain if you stall at a stop light.
    BEST SOLUTION:
    Spend $15 on a new switch.
  9. mtnbikecrazy55
    sounds like the best thing to me!
