Ground wires
Discussion in 'XJ Technical Chat' started by KVB_650, Aug 14, 2011.
  1. KVB_650
    KVB_650 Member
    Quebec
    On my 82 Seca 650, there are two big ground wires at the back of the engine block. The one on the left goes to the battery, where does the one in the centre of the block go to?.
    Ken
  2. wizard
    There is only one big ground wire from the motor to the battery.
  3. Polock
    one goes to the battery the other to the frame,so if all your motor mount bolts fall out you'll still have lights :)
  4. bigfitz52
    I'll look when I get home and give you a more specific answer.
