grrrrrrr.....bench sync frustration
Discussion in 'XJ Technical Chat' started by mmcgee, Apr 27, 2013.
  1. mmcgee
    mmcgee Member
    Man, I have been adjusting the tang on carb 4 all day. No matter which way I bend it, the fuel level is way low. It lines up with the bottom of the carb, level with the drain nipple.
    What am I doing wrong?
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Maybe the needle is sticking in the seat. Leave it out and see what happens.
  3. mmcgee
    mmcgee Member
    Not sticking. I've checked it with the bowl off.
  4. bigfitz52
    The title of this thread is "bench sync frustration."
    But it's another float level question; which you are already running a thread on. http://xjbikes.com/Forums/viewtopic/p=3 ... tml#373516
    "Bench sync" involves the basic synchronization of the carb butterflies prior to a vacuum sync, it doesn't involve float levels.
    Let's continue to discuss float levels in your float level thread.
