Halp!
Discussion in 'XJ Technical Chat' started by mr_biscuits, Oct 12, 2010.
  1. mr_biscuits
    mr_biscuits New Member
    Sorry to be a bother, but I'm really REALLY new to motorcycles. Wife just got an '81 XJ 650. Brand new spark plugs installed, turns over but wont start. Fresh battery is installed. Couple "newb" questions: Fuel line has a wing nut type thing on it... what do I do with that? And also the selector for "res", "pri" and something else on the left side... what do I have to have that on? Thank you in advance for all your help.
  2. iwingameover
    iwingameover Active Member
    What wing nut thing? Picture perhaps?
    PRI - Prime fuel flows from tank constantly. Use to fill empty carbs or when first starting the bike for the day.
    ON - normal operating position fuel flows when vacuum from engine works fuel valve
    RES - the last 0.8 gallons to get you to a fuel station when you run out of ON.
  3. mr_biscuits
    Okay well perhaps I can't start it because it's been on "ON". Thank you! Once again sorry I'm new.
  4. mr_biscuits
    Didn't work... Still just turns over forever.
  5. Ravenz07
    Ravenz07 Member
    Its supposed to be on "ON" Thats your primary running part of the petcock. Unless your really low on gas?
  6. Ravenz07
    Ravenz07 Member
    Have you tried any starting fluid?
  7. schooter
    do you have spark? and your carbs could be dirty, you up to rebuilding them?
  8. mr_biscuits
    Haven't tried starting fluid yet. How do I check for spark? And I'm definitely not up to rebuilding them. Luckily my neighbor has a bunch of mechanic friends.
  9. Ravenz07
    Ravenz07 Member
  10. mr_biscuits
    Yes about two years.
  11. Ravenz07
    Ravenz07 Member
    Carbs will definitely need to be rebuilt then. Its a sad, unfortunate thing, but chances are you wont get it running at all until that is done.
  12. RickCoMatic
    Check for Spark:
    Place a Spark Plug in one of the Spark Plug Wire Caps.
    Hold the Plugs Business end to GROUND on the Head with a pair of Lineman Pliers.
    Crank-over the Engine and L@@K for Spark to jump the Plug Gap.
    Complete the Registration Process:
    SIGNATURE SECTION:
    Year – Model – Miles – Stock or Mods??
    LOCATION Section:
    Fill-Out Location.
  13. bigfitz52
    Rick's right. Get us some specifics on this bike: how long it sat, its history if you know it or what you know if it, how many miles are on it, what the PO (Previous Owner) told you about it.
    Then, some idea of where you are, both geographically and mechanical skills-wise.
    Then, how committed you are to THIS BIKE or were you expecting a miracle cure (cuz that ain't happening.)
    Because before it ever gets ridden ONE FOOT there is a lot more to be attended to than the carbs. You up for this?
    Then welcome aboard. START HERE, honest: http://xjbikes.com/Forums/viewtopic/t=15874.html
  14. mr_biscuits
    The thing is... the guy drove it the day we bought it. He drove it top a ramp at his place of work to load it into my truck. He said he drove it to the store all the time and the carbs just needed to be tuned.
    1981 Xj650, 25k miles, stock.
    Located in Minot, North Dakota. Purchased in Bismarck, North Dakota
    Also... sediment in the gas tank...why??
  15. RickCoMatic
    Sediment in the Gas Tank is BAD NEWS.
    It means the Bike is getting OLD and/or SAT.
    The Petcock Screen cannot be depended upon to protect you from particulate that will foul the Carbs.
