Haps brake line guide
Discussion in 'XJ Technical Chat' started by bkerby, May 27, 2011.
  1. bkerby
    bkerby Member
    MO
    Anybody on here ever use Haps Stainless steel brake line guide to order from Rennsports? It is posted on the xjcd site. It is for xj 700x/750x. Thinking about it but wanted feed back first.
  2. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Is this what you're looking for?
    Dear rennsportautoparts,
    I saw on a forum I subscribe to that you do a set of SS lines for the 85-86 Yamaha XJ750 MaximX
    Here are the specs:
    HAP'S Stainless Steel BRAKE LINE GUIDE
    Submitted by HAP on Sun, 04/04/2010 - 22:49
    Applies to
    1985/86 Yamaha XJ700X / XJ750X Maxim-X
    1985/86 Yamaha XJ700 Maxim
    ----- 3-PART BRAKE LINE GUIDE ------
    Upper Brake Line
    Quantity
    Length 1
    43.0cm (16.9in)
    Upper Fitting 2
    Type #3 - 10mm / 15°
    Lower Fitting 2
    Type #1 - 10mm / straight
    Orientation 3
    Type C - 90° Rotation
    Lower Brake Line
    Quantity
    Length 1
    55.5cm (21.9in)
    Upper Fitting 2
    Lower Fitting 2
    Orientation 3
    Could you contact me with a price for the above set?
    My email is
    Maximx@rogers.com
    Also if you could include pictures of the lines or a link to where I can see the set, I'd appreciate it.
    Just down the road in London,
    Graham
  3. bkerby
    bkerby Member
    MO
    Sorry I wasnt real clear on my question, I found the guide but really just wanted to make sure it was accurate, and would fit. I am assuming you indeed have ordered these? Did everything fit up right and did they come with all the necessary pieces and parts?
  4. Maxim-X
    Oh, ok.
    I've yet to install the lines, but by holding them up to where they are supposed to go, they look like a perfect match and they came with all new chrome banjo bolts and copper crush washers. I haven't got to that point on the rebuild yet, but when I do I'll take some pictures and post them. The parts arrived quickly and were very well packed in a heavy cardboard box and the parts were wrapped in sealed plastic bags if thats any help.
  5. bkerby
    bkerby Member
    MO
    Thank you sir, thats what I was looking for. Gonna order a set myself. Appreciate your response very much.
  6. commanderdrako
    commanderdrako Member
    Michigan
  7. commanderdrako
    Michigan
    Where can I order those brake lines? How about the brake pads?
    Where can I order it?
  8. bigfitz52
    You don't need to get them from Canada unless you really want to; XJ4Ever does stainless lines, in various colors, including custom lengths for very reasonable prices. I've got them on both of my 550s, with custom-length upper lines.
    He also carries OEM as well as aftermarket pads, EBC rotors, etc.
    If you're not familiar with XJ4Ever, you need to be unless you want to spend way too much money doing this. Click on the logo/link in the site banner at upper right, PM member chacal or send an email to 'info "at" XJ4Ever "dot" com' and let him know what you want to do.
    You're going to want to rebuild your caliper and master cylinder while you're at it. If you don't the bike will make you as soon as you start riding it. Honest.
  9. commanderdrako
    Michigan
  10. commanderdrako
    Michigan
  11. bkerby
    bkerby Member
    MO
    Rennsportauto can be found on ebay, and is quite a bit cheaper than xj. I have been very happy with my brake lines from them and fit was spot on. Having said that, Chacal is a great guy and has top notch parts, I have ordered many items from him as well and have been very happy. In the end it was $$$.
