Harbor Freight Vacuum Gauges
Discussion in 'XJ Technical Chat' started by MisterShah, May 23, 2012.
  1. MisterShah
    MisterShah Member
    Tucson, AZ
    Hello everyone, just wanted to share this info in case anyone is in the market for vacuum gauges to do a carb sync. Harbor Freight has single gauges on sale for $9.99. Seems like they will do the job. I got sick of using the bottles. Picked up a pair for $20.
    Here's the link if anyone is interested: http://www.harborfreight.com/fuel-pump-and-vacuum-tester-93547.html
  2. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Sweet! I have a dirty love affair with Harbor Freight
  3. biggs500
    biggs500 Active Member
    Sherwood WI
    This type of gauge doesn't work well at all for syncing. These are meant to read a constant vacuum, not the pulsing kind you'll get from an engine. The needle will bounce all over. Perhaps getting gauges filled with mineral oil would work but these won't. :(
  4. MisterShah
    MisterShah Member
    Tucson, AZ
    Yeah, I found that out last night. Needles flying all over the gauge.
    They are going back.
  5. bigfitz52
    you have to "damper" them way down (you do with a CarbTune, too.) Install restrictors in your lines (small pieces of spray-straw work) and see if that doesn't smooth them out.
  6. MisterShah
    MisterShah Member
    Tucson, AZ
    Yeah, I made Rick's restrictors and they didn't help. After that I stuffed cloth before the restrictors on the gauge side and it smoothed them out, but it didn't appear to be an accurate reading and it didn't respond to changes.
    Oh well, the bottles work well enough til I can get a Carbtune or similar.
    Fitz, you are the valve clearance expert...can you check out my other thread?
