hard tail how to
Discussion in 'XJ Modifications' started by XJ89, Mar 15, 2013.
  1. XJ89
    XJ89 New Member
    Langley BC
    heyy all iam buildin on a 800 xj 650 an would like ta know what type of metal pipe i would use to go tgo a hardtail[​IMG]
  2. Demin
    Demin Member
    Youngstown,Ohio
    You want seamless DOM tubing
  3. JohnStonePhoto
    JohnStonePhoto Member
    The Woodlands, Texas
    Hard tail how to? My opinion is don't. A lot of time and money went into engineering these bikes to near perfection. Personaly I wound leave the basic structure/integrity in tack and go for only cosmetic mods for the safety factor. Just my opinion.
  4. XJ89
    XJ89 New Member
    Langley BC
    how thick ? i got the bike all riped down just need the 2 bars an some braceing
    thanks for the quick replies
  5. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    click the image icon in the toolbar (looks like mountains with the sun) which appears above the message body txt box when you do a new post or reply; a separate box will appear; delete what's in the box; put your cursor in the box; right click and paste your copied img code there. Your picture will display in your post.
  6. 750E-II_29Rbloke
    South Cheshire, UK
    Not sure if it was a valid path anyway, it's not showing the pic when I add it.
    If the O/P corrects the path & does what you say it will work then 8) I wanna know what this "beast" is now!
  7. Orange-n-Black
    Memphis Area
    TCBrothers has a hardtail kit for 125 bucks. Just keep in mind that a hardtail requires different riding skills and will be hard on your back and tail.LOL
  8. XJ89
    XJ89 New Member
    Langley BC
    iam jus lookin for the chepest way its not goon be for road use just a put around my small town an for burnouts.. ive got a pic in my photo album since iam havein dificualties posten em
  9. Demin
    Demin Member
    Youngstown,Ohio
    Usually want around .120 wall thickness.Pretty much all I ride are rigids.They're not as bad as everybody says.I'm 48,6'3",270lbs.As long as you do the geometry.If you strut a bike,usually they are worse than a true hardtail.The shock travels up the rear tubesIf it's strutted they usually are right inline with your back.
  10. XJ89
    XJ89 New Member
    Langley BC
    i wish i could figuar this picture thing out but theres one in the photo albums its that beast lookin drag bikke
  11. Orange-n-Black
    Memphis Area
    TCBrothers has a 4ft section of .120 pipe for 20 bucks. Look here:http://www.tcbroschoppers.com/weld-on-hardtails/extra-frame-tubing-4ft.html
  12. sebwiers
    sebwiers Active Member
    I wouldn't pay extra for seamless dom. The factory tubing is plain old electroweld (I've cut through enough to know). 1" by 11 gauge should match the frame members quite well (that's a nominal 1/8" / 2mm wall). I'd guess it might even be US made steel, or made to match some US size; the US still dominated the steel market back then, after all.
  13. XJ89
    XJ89 New Member
    Langley BC
    thanks evreyone much help :) ill get pics posted when its all painted up an doin a badass burnout
  14. TIMEtoRIDE
    Search for "Crath" and check out his bike XJ89 (trust me)
  15. XJ89
    XJ89 New Member
    Langley BC
    that was the first build i looked up when i first found this sight verry nicee
