hard to start xj700 watercooled
Discussion in 'XJ Modifications' started by dowski68, Jul 9, 2013.
  1. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    Bought my first 1986 maxim x bike and ever since I have owned it I have to baby sit the throttle when it is cold 32-60 degrees outside. It has a tune up well plugs/regular oil changes/carbs rebuilt/and know I just put on K&N pod filters-also uped the jets 15% from stock. Runs like a champ however I still can't get the flippin choke to work. I mean the slides go back and forth all right it just kills the engine everytime I try to use it.
    Any ideas?
  2. jayo84
    jayo84 Member
    Irwin PA
    There is a lot of threads regarding the enrichment circuit (choke)on our bikes. I believe you may have plugged carb bowl. Its where the brass needle goes into your carb bowls and you have to use a correct drill bit to clear the plug. Chacal on these forums has the parts you will need. There is a write up about how to clean it on here somewhere..
  3. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    yea... sounds like you need some more carb cleaning.... Pods + jets are not making it any easier too.
    Are you fouling plugs, or too lean?
  4. jmilliken
    Dillsburg, PA
  5. farmer
    farmer Member
    check valve clearances
