have a question
Discussion in 'Hangout Lounge' started by fossilbike, May 11, 2014.
  1. fossilbike
    fossilbike Member
    converse tx
    hello,I was wondering if anyone out there knew what the initial setting of the pilot air screw is for a XJ 750 RK seca1983 is. Is it two and a half to three turns out or is it one and three quarters to two turns out im having the hardest time trying to get the correct answer
  2. fossilbike
    fossilbike Member
    converse tx
    83xj750rk seca need initial pilot air screw setting?
    Is this setting 2.5-3.0 or 1.75-2.0 turns out? Thank you anyone who knows the truth.
  3. Beck
    Beck Member
    New Hampshire, United States
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Not sure either. A good tip that I picked up here was prior to removing the screws; screw them in and count how many turns until they bottom out.
    I don't have my exact numbers in front of me but they ran in an approximate range from 1.75 - 2.25 turns (81 XJ 650 Maxim).
    Good luck!
  5. Polock
    2 3/4 - 3 better rich than lean. you should get 4 adjustments from 2.75 to 3
    out is richer
  6. k-moe
    Yep. I started with 2 1/2 turns out, and colortuned from there. Every pilot screw came out at least another 1/4 turn to get it spot on.
  7. fossilbike
    fossilbike Member
    converse tx
    Thanks everybody. Fossilbike
