Having issues with starting while at operating temp
Discussion in 'XJ Technical Chat' started by Donglord, Apr 7, 2026 at 12:55 PM.
  1. Donglord
    Donglord Member
    Arkansas
    (I believe the bike is a ‘82 xj750) The issue I’m having, is when I got to start it up on a cold start, she fires right up after maybe 2 or 3 cranks and sounds great. She’s rides extremely well and has no issues. But after I’ve ridden a while and I shut it off, if I go to start it while it’s hot then the stater sounds super crunchy like it’s not making full contact. It’s sounds like it’s catching for a half second, then is super crunchy. I’ve tried this with 2 known good starters and known good batteries. After I let it sit over night (or let it cool completely) the issues disappears and the bike fires right up. Any advice is helpful
  2. Dan Gardner
    Minneapolis, MN
    That noise is the starter clutch failing to engage. Common problem. Gets worse with time and heat.
    Start here:
    https://www.xjbikes.com/forums/thre...building-your-slipping-starter-clutch.130438/
    Unfortunately, reviving the starter clutch is no small task - at a minimum you need to pull the engine and split the cases to get to the starter clutch. Once you go that far there is a lot of other "while you're in there" things you could do.
    I just rebuilt one over the winter and installed new springs in the starter clutch. Haven't had it out a hot day yet (have had no hot days yet), but so far so good. Here is my story:
    https://www.xjbikes.com/forums/threads/shell-rotella-t6-15w-40-synthetic-oil-experiment.132471/
  3. Donglord
    Donglord Member
    Arkansas
    I read the thread about the other things it MAY be. I haven’t noticed any drive clutch slipping at all. I can probably give the Seagram treatment a go and see what that does. But if all else fails, do you happen to have a link to a thread that takes me through the steps of splitting the case and replacing the old starter clutch?
  4. Dan Gardner
    Minneapolis, MN
    Yes, @Jetfixer did a thread on it: https://www.xjbikes.com/forums/threads/dreaded-starter-clutch-replacement.130190/
    Also, get a Haynes manual (or similar).
    While you're in there, you will 100% want to replace the primary chain guide.
    Then you have to decide how far you want to go and what your budget is - personally, if I'm getting that far into it I would at least want to hone the cylinders and lap the valves. All the gaskets and o-rings and stuff isn't free, so you need to budget for it.
