Having trouble location VIN number
Discussion in 'XJ Technical Chat' started by Dalexander, Jun 24, 2020.
  1. Dalexander
    Dalexander New Member
    Toronto
    Having a hard time finding the VIN number on my 1981 xj650 maxim. I bought this bike recently for $180 without ownership and it has been partially modified and I was told the frame was painted but I thought I would still be able to see the stamp, I googled where it should be but I checked neck and no luck I did find what looked like a “7 20” on the frame under the tank. Any tips or is this just a parts bike? Thanks
    there is a short vin on motor near clutch lever.
    vin should be stamped into neck on right side of bike 3ed photo. paper labels were put on left side
  3. Dalexander
    Toronto
    Thanks for your reply, I can’t see anything stamped into the neck on either side but I did find the number on the motor near clutch lever I’ll add the pic
  4. XJ550H
    Jya4w6003ba000151 is full vin 1981 650 midnight Maxim. There should be a VIN on the neck. Maybe it has been painted over well and you can't see it. Not sure if Canada will allow you to register bike with motor Vin.
    There is a company in Canada which reproduces the VIN labels but you may not have enough information for them to do it. It
    Dalexander likes this.
  5. XJ550H
    If there is no Vin stamped on the neck it may be a replacement frame which would have had documentation standing it's a replacement frame. If the neck is clean of numbers you could probably buy the metal stamps and put the VIN number back on yourself just takes a hammer and paint back over it. I do not know if this is legal in Canada or if anyone would notice that you did it yourself on a clean frame.
  6. Eric Hughes
    Eric Hughes Member
    North Carolina
    Is the 4W6 a Canadian designation?
  7. XJ550H
    yes that part of the vin ids where the bike made for, as there are different specs for different countrys
  8. Eric Hughes
    Eric Hughes Member
    North Carolina
    Cool I was wondering. My 81 650 midnight maxim is 4w5..
  9. chacal
    USA Midnight Maxim models got the 4W5 model ID code, while Canadian MM models got the 4W6 code........
  10. Dalexander
    Toronto
    I found a company in Canada that reproduces them but online my model of bike is not listed, so I will try to remove some of the paint on the neck to see if I can find the VIN. Thank you
  11. Eric Hughes
    Eric Hughes Member
    North Carolina
    Right side of the neck fault large probably the same stamp size as the engine. Here is a photo of mine. Maybe whoever stamped yours had a light hammer and it’s buried under new paint.
  12. Dalexander
    Toronto
    Great thank you, I will try today and let you know if it works. I had a hard time even finding a pic of a vin just so I could locate it better so that helps a lot. Thanks
  13. Dalexander
    Toronto
    Scraped the paint off the right side of the neck with a heat gun and wire brush and there was nothing under the paint
  14. chacal
    Replacement frame or factory goof!
  15. k-moe
    I thought I was the factory goof around here.
  16. chacal
    You are, but you're probably stamped somewhere..........:)
  17. Dalexander
    Toronto
    I found a company here that reproduces VINs and sent them all the info I had and they said they could reproduce it, great news! Thanks so much
  18. Eric Hughes
    Eric Hughes Member
    North Carolina
    I wonder if it was bike somebody built up, maybe original frame was bent/rusted/something and they just took a grinder to the VIN on that one since it didn't match. Can you share the info of who is reproducing it for you? I'd like to get a new sticker for mine, it is barely holding together since I removed it.
  19. Dalexander
    Toronto
    Sorry for the late response, the company is called bdesigns and their website is bdesigns.ca the owner Brian was really helpful. Turns out it’s going to be a bit of a hassle to register my bike so it might just have to be a parts bike, I’m going to keep my eye open for another xj This time with ownership and VIN and hopefully I’ll be back on this forum soon.
  20. hogfiddles
    If you decide to part it out, and want to come to the CNYCC#14 next June, I could sure use that frame.... hint hint hint
  21. Eric Hughes
    Eric Hughes Member
    North Carolina
    There is always Vermont.
  22. hogfiddles
    Even that loophole would be tough since there’s no VIN on the frame for a cop to verify. He’d hafta go by the number on the engine......and WHAT IF it’s not the original engine and that came from a wrecked bike— you’d have a headache.
