Having trouble putting back cam shaft. Pls help.
Discussion in 'Hangout Lounge' started by commanderdrako, Jun 14, 2012.
  1. commanderdrako
    commanderdrako Member
    Michigan
    Okay I cleaned the carbs and decided to adjust the valves on my Maxim X. Now I can not put back the intake cam shaft, I removed the cam tensioner sticked my finger in the whole but there still not enought slack on the timing chain. What am I missing? Any help would be much appreciated!!!
  2. adrian1
    adrian1 Active Member
    Ru sure it's not hooked up somewhere at the bottom of the tunnel?
  3. mlew
    mlew Well-Known Member
    Apex, NC
    Did you line up the timing marks on the crankshaft and cams like the manual explains?
  4. commanderdrako
    Michigan
    Yes I did lined it up. I will check again if it got stock in the bottom.
  5. junkmn
    junkmn Member
    Colorado
    I just did this. Do you have the sprockets bolts removed so you can get the chain onto the sprocket, then the sprocket replaced on to the cam shaft?
