Head cover gasket
Discussion in 'XJ Technical Chat' started by Trainer6, Feb 22, 2016.
  1. Trainer6
    Trainer6 Member
    Ontario, Canada
    I have trouble trying to install the rubber gasket for my xj 550. It is tricky enough to get the head cover off and on with scratching it little own trying to put on a new gasket. I have tried spray tack but it does not hold in place and makes a mess. Does anyone have any suggestions or is there a how-to-video that someone has done?
    make sure groove is clean
    use oil resistant black rtv a small small bead around the groove push gasket in place. let it cure
    if you have to tape it in place as you go around the cover just small stripes
    Trainer6 likes this.
  3. k-moe
    Get this.
    Brush it onto the gasket channel in the vave cover. Insert gasket. Install cover.
    DO NOT apply to the gasket face that seats on the head.
  4. Trainer6
    Trainer6 Member
    Ontario, Canada
    I was using the spray version of the same thing. It make a mess. I will look tomorrow for the liquid version. I will let you know how it goes.
  5. k-moe
    No need to buy a different can. Spray some into a paper cup and use an artist's brush to apply it.
  6. KrS14
    KrS14 Active Member
    St Marys, Ontario
    ^^^ Do this, be sure to let it cure though after you put the gasket in the groove. Makes things much easier.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
