head light
Discussion in 'Hangout Lounge' started by TheCableGuy, Jul 18, 2010.
  1. TheCableGuy
    TheCableGuy New Member
    82 xj 650 bike starts and runs fine blinkers work tail light works but head light not working looks like the bulb is good high beam nothing either im guessing theres a relay because when u turn the key on the head light would stay off till it actually started but now nothing any ideas where the relay or what to check on thanks
  2. chacal
    Headlight Relay:
    Identification:
    - small metal "cube" relay, inked 3H5-00 on the top face.
    - has a yellow (yellow) paint mark on the bottom terminal connector block.
    - plugs into a connector shell which has the following set of wires going to it:
    Harness connector wire colors:
    - on all XJ550 all models, XJ650 all models (except Turbo):
    * Blue wire with black tracer stripe
    * solid White wire
    * Red wire with yellow tracer stripe
    * solid Black wire
    - on all 1981-83 XJ750 Seca models:
    * White wire with blue tracer stripe
    * solid Black wire
    - on all XJ550 models: under the gas tank, in-between the frame tubes, on a welded bracket just behind the flasher self-canceller relay.
    - on all XJ650 Maxim/Midnight Maxim/RJ Seca models: behind left side cover, below the TCI and Regulator-Rectifier unit.
    - on all 1981-83 XJ750 Seca models: behind the left side cover, below the TCI and Regulator-Rectifier unit.
    All other models do not use a headlight relay.
    BY-PASSING SWITCHES AND RELAYS:
    How to bypass various relays: first of all, our advice is DON'T. The relays and switches are there for a reason....your safety, to prevent "mistakes" from turning into "disasters".......so our recommendation is to just leave the system as it is, and replace any components that fail. However, for failure testing purposes, it may be necessary to temporarily "by-pass" certain components, thus elminating their functionality from the circuit, to see if they are the source of whatever problem is occurring.
    Headlight relay:
    - bypass the relay by connecting the Blue wire with the black tracer stripe directly to the Red wire with the yellow tracer stripe.
  3. TheCableGuy
    well i fixed it i was looking at some pic on here and saw a fuse box on the air box of a bike , i havent see the fuse box on mine but there is a bunch of wires spliced and taped well the fuse box was removed and all the wires spliced there i found the bad connection problem solved .... but now i need to get a fuse box back in there does anyone know the fuse size and what these wires go to thanks for the help
  4. hogfiddles
    You can put an original fusebox back in if you're going the original-only route. HOWEVER, since it's already missing, I'd recommend doing a fusebox upgrade and put in the blade-type connectors with the blade-style fuses. You won't have to worry about any of the fuse clips breaking off, unavailability of glass fuses, etc.....
    There are how-to articles on this site for you to follow. Just ask someone to dig up the links.
    Dave Fox
  5. bigfitz52
    Generally speaking, you have a MAIN, IGN, HEADLIGHT and SIGNAL fuse; but it varies by bike and some variations include fuses in other locations. Without knowing what bike (and without you getting ahold of a wiring diagram) we won't be much more help.
