Header nut torque
Discussion in 'XJ Technical Chat' started by eflat7, Feb 3, 2009.
  1. eflat7
    eflat7 Member
    Does anyone know what the torque specs are for the headers on 81 650 maxim? I am running open headers and guessed the torque and one fell off after about 6 mos. HEHEHE!
    Thanks.
  2. Robert
    Flat, you should have a fresh set of lock nuts and run them down at 7.4 ft/lbs.
  3. eflat7
    eflat7 Member
    Thanks!! I appreciate the info.
  4. bill
    bill Active Member
    Raleigh, NC
    Bobby are you talking about the flange nuts? Those are 5.4 ft/lbs
  5. Robert
    I was referring to the Exhaust Port nuts (securing the header pipes to the head). The Haynes has them at 7.2 ft/lbs (pg 111 section 8) while the factory manual only mentions a general torque for an M6 at 4.5 ft/lbs. I pulled my number down off the top of my head but I would use the 7.2 ft/lb.
    Use a German torque wrench, gut und tight.
  6. bill
    bill Active Member
    Raleigh, NC
    Interesting - look at page 43 in the table and it says 5.4 Page 111 does indeed say 7.2. I had just looked it up the night before because I replaced my exhaust seals. I always look in the chart. Another Haynes inconsistency!
  7. Robert
    Somehow that error doesn't make me like my Haynes any less (I'm a sentimental fool, I know).
    A quandary for sure. Since there seems to be consistency between the factory manual and the Haynes general fastener chart, I'm starting to think that a the general chart for fasteners should take precedence.
    What are your thoughts?
  8. bill
    bill Active Member
    Raleigh, NC
    I love my haynes too - use it all the time. I'd have to agree with you on the chart 7.2 is usually the minimum I see.
  9. Robert
    Well now, I've run mine at 7.2 all these years without a single issue. What has been your experience with 5.4 ft/lbs? I would think that if you could get the same reliability from a lower torque value, you ought to use it. Any troubles? Find anything loose on your annual torque check?
  10. bill
    bill Active Member
    Raleigh, NC
    Well they came off easy when I changed the seals last week. I had them off this summer. But at 5.4 they would loosen easy - that and anti-seize
  11. TIMEtoRIDE
    Maybe the difference is between a regular fastener, and a locking fastener?
    Hey, my torque wrenches don't even accurately register below 20 LB,
    What torque wrenches do you guys prefer?
    I can sneeze harder than 5.4 8O
  12. turtlemann14
    turtlemann14 Member
    my hand does a excellent job...
    just drill a hole in the end of your ratchet and use a pull scale :) redneck ingenuity
    6" away from axis X scale readout by 2 to get foot pounds
    12" give you total ft-lbs.
  13. Robert
    I have a set of...yer gonna laugh at this one...Harbor Freight specials. 3/8" and 1/2". I do have a beam inch pound 1/4" Snap-On but I only use that for setting steering shaft bearing preload and wheel bearing preload. I also own a set of Craftsman and a set of Sturtevant Richmont (they are super nice!). I had the Harbor Freight specials checked at a calibration lab I was working at at the time and they spec'd in within 5%. Not bad at $18 for the set! They get me down to 5ft/lbs but I'm always leery of anything towards the ends of the scale. For what I do, my Harbor Freight specials have served me well at a fraction of the cost of my "cadillacs" and I've not had a torque related failure yet. Now keep in mind that I excersize caution when reusing fasteners and will replace anything that even looks the slightest bit funny. No sense taking chances.
  14. bill
    bill Active Member
    Raleigh, NC
    +1 with Robert - I have the 3/8 and 1/2 Harbor freight specials....
  15. eflat7
    eflat7 Member
    I appreciate all the info!!
  16. bill
    bill Active Member
    Raleigh, NC
    Bobby your bike is looking great. Keep us up to date ...
