Headlight bracket.
Discussion in 'XJ Modifications' started by wraith0078, Jul 14, 2008.
  1. wraith0078
    wraith0078 Member
  2. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    You mean like these: Ebay
  3. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    The one from nxpowersports is the ony "correct" one....
    It is an oddball unit....
    One of the main reasons I'd like to ditch mine , that and it's bent.
    The Dennis Kirk ones look like they're worth a shot....
  4. wraith0078
    wraith0078 Member
    Yeah, mine's bent too. I might give the one's from Dennis Kirk a try.
  5. earz_cd
    earz_cd Member
    Jefferson city, MO
    K&L supply offers some exactly like those on Dennis Kirk. Unfortunately you have to go to an authorized dealer to order them.
  6. mtmadman
    mtmadman New Member
    Currently in ST. LOUIS
    I used some off of a cb 500 mid 70s they worked great!
  7. wraith0078
    wraith0078 Member
    If I use one of those, where can I put the turn signals? Any suggestions for aftermarket signal mounts or do you think I can mount them to these?
  8. ZaGhost
    ZaGhost Member
    Good question, you may need to fab up something for that, or swap out for new signals :)
  9. wraith0078
    wraith0078 Member
    I'd love to, but I don't have access to the kinds of tools I'd need for that.
    One way to find out I guess...
  10. mtmadman
    mtmadman New Member
    I was able to use the stock turnsignal mounts on my bike, I dont know if they are diffrent on a Maxim.
  11. krayzeesmoke
    krayzeesmoke Member
    Lexington, KY
    Has anyone tried to use these signals
    chrome signals
    I just got a xj750 Seca (first bike) and am looking at the options while it is in the "repair" stage and I was wondering about the headlight brackets also.
  12. chacal
    I carry the stock style turn signals and their mounts (new), as probably have a good used headlight bracket for that puppy......
    TURN SIGNALS:
    The stock Yamaha turn signals on these bikes are a "beauty in the eye of the beholder" kind of thing: either you love 'em or hate 'em. Most people don't object to the size of them....in fact, when it comes to turn signals, you want the cager who's heading towards you---you know, the one who is on the cellphone who's also fiddling with the radio dial and swilling coffee at the same time---to NOTICE you, and a large, bright turn signal is a big advantage here. But they do stick out quite a bit more than most people would prefer, looking like big alien ears of some kind........well, nothing's perfect, is it?
    We can help restore your flashing bunny ears with a variety of high-quality OEM or aftermarket parts.
    Complete Turn Signal Assembly:
    Brand new, exact reproduction front or rear TURN SIGNAL ASSEMBLY units are now available. Finished in the correct mirror-polished chrome plating, or the smooth-textured, low gloss black finish, these complete, assembled, pre-wired DOT-approved assemblies bolt up directly in place of your stock unit, using the same hardware and mounting points as the originals. Lead wire colors are different from original, but the wires include the correct male bullet connectors so that they will plug directly into your existing main harness terminals.
    Most model turn signals are available in both a two-wire and a three-wire design. Two-wire signals operate only as flashers (turn signals), while the 3-wire design signals operate both as running lights and as flashers (3-wire signals were originally used only on the front of XJ700 and XJ1100 models). If you desire, you can upgrade your standard 2-wire "flashers-only" to the three-wire design and have your turn signals also function as running lights (check with your local laws to determine legality of doing such a modification).
    All turn signals are complete assembled units, and contain the housing, the wire harness, the lense, lense gasket, and a standard incandescent bulb.
    HCP7557 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, low gloss black rectangular housings, 2-wire design (flashers only), with "wrap-around" rectangular orange lense is correct for all of the following models: XJ650 Turbo rear, and XJ750 Seca front or rear. See the NOTES below regarding these turn signals. Each:
    $ 29.95
    HCP7557SET2 Aftermarket TURN SIGNAL ASSEMBLY, set of 2:
    $ 56.00
    HCP7557SET4 Aftermarket TURN SIGNAL ASSEMBLY, set of 4:
    $ 99.95
    [b/]NOTES ON HCP7557 SIGNAL UNITS:[/b]
    a) these turn signals are also the same shape and fitment for the XJ900RK models, but they have the black housing rather than the chrome housing used originally on those models.
    HCP7558 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, low gloss black rectangular housings, 3-wire design (flashers and running lights), with "wrap-around" rectangular orange lense can be used on all of the following models: XJ650 Turbo rear, and XJ750 Seca front or rear. See the NOTES below regarding these turn signals. Each:
    $ 29.95
    HCP7558SET2 Aftermarket TURN SIGNAL ASSEMBLY, set of 2:
    $ 56.00
    HCP7558SET4 Aftermarket TURN SIGNAL ASSEMBLY, set of 4:
    $ 99.95
    [b/]NOTES ON HCP7558 SIGNAL UNITS:[/b]
    b) these turn signals are the same design and style as the stock signal units, which were originally a 2-wire (flashers only) design. The 3-wire design of these signals allows them to be used as running lights as well as perform their flasher function. Models not originally using their turn signals as flasher lights can be converted by tapping into the rear brake system running light circuit (usually a blue wire) and running that wire to the running light wire lead on these turn signals. Check your local laws for the legality of using running lights on vehicles not originally equipped with them.
    C) These turn signals come with a flexible black plastic protective sheathing over the wire harness lead wires. However, this sheathing is difficult, if not impossible, to force through the rubber turn signal mounting stays as used on the XJ650 Turbo and XJ750 Seca (rear) models. Thus, we recommend that you remove the sheathing from the wire harness lead (it slides off) before installation. However, be aware that once the sheathing is removed from the wire leads, it is very difficult (if not impossible) to re-install it! The sheathing will fit through the front (only) turn signal mounting "covers" used on the XJ750 Seca models.
    HCP7559 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housings, 2-wire design (flashers only), with "wrap-around" rectangular orange lense is correct for all of the following models: XJ900RK Seca front or rear. See the NOTES below regarding these turn signals. Each:
    $ 29.95
    HCP7559SET2 Aftermarket TURN SIGNAL ASSEMBLY, set of 2:
    $ 56.00
    HCP7559SET4 Aftermarket TURN SIGNAL ASSEMBLY, set of 4:
    $ 99.95
    [b/]NOTES ON HCP7559 SIGNAL UNITS:[/b]
    a) these turn signals are also the same shape and fitment for the XJ650 Turbo rear and XJ750 Seca front or rear, but they have the chrome housing rather than the low gloss black housing used originally on those models.
    HCP7562 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housings, 3-wire design (flashers and running lights), with "wrap-around" rectangular orange lense will fit all of the following models: XJ900RK Seca front or rear. See the NOTES below regarding these turn signals. Each:
    $ 29.95
    HCP7562SET2 Aftermarket TURN SIGNAL ASSEMBLY, set of 2:
    $ 56.00
    HCP7562SET4 Aftermarket TURN SIGNAL ASSEMBLY, set of 4:
    $ 99.95
    [b/]NOTES ON HCP7562 SIGNAL UNITS:[/b]
    c) These turn signals come with a flexible black plastic protective sheathing over the wire harness lead wires. However, this sheathing is difficult, if not impossible, to force through the rubber turn signal mounting stays as used on the XJ900RK Seca (front and rear) models. Thus, we recommend that you remove the sheathing from the wire harness lead (it slides off) before installation. However, be aware that once the sheathing is removed from the wire leads, it is very difficult (if not impossible) to re-install it!
    Turn Signal Mounting:
    tsm1) OEM and aftermarket replacement turn signal-to-frame MOUNTING HARDWARE perfectly replaces missing, worn, or incorrect stalks, stems, and fasteners. All items work with both our original or reproduction turn signal units.
    NOTE: the signal STAY is the chrome or black rubber stalk or stem that attaches to both the turn signal housing "neck" and runs to the adapter bracket or directly to the frame mounting point. These stays are hollow, and thus allow the signal wires to pass through them. The CINCH BOLT and related hardware items are what attach the above stay to the turn signal housing to lock the stay to the turn signal.
    HCP1981 OEM turn signal STAY, flanged black rubber mounting stalk with the hollow threaded mounting collar used on turn signals for these models: XJ550 Seca front or rear, XJ650 Turbo rear, 1982 XJ750 Maxim rear, XJ750 Seca rear, and XJ900RK models front or rear. Each:
    $ 28.95
    HCP1981SET2 OEM turn signal STAYS, set of 2:
    $ 55.95
    HCP1981SET4 OEM turn signal STAYS, set of 4:
    $ 109.95
    HCP6434 Aftermarket turn signal STAY, flanged black rubber mounting stalk with the hollow threaded mounting collar used on turn signals for these models: XJ550 Seca front or rear, XJ650 Turbo rear, 1982 XJ750 Maxim rear, XJ750 Seca rear, and XJ900RK models front or rear. Very nice reproduction of the originals. Each:
    $ 11.95
    HCP6434SET2 Aftermarket turn signal STAYS, set of 2:
    $ 21.95
    HCP6434SET4 Aftermarket turn signal STAYS, set of 4:
    $ 39.95
    HCP3563 OEM turn signal STAY BUSHING, flanged black rubber hollow "bullet" fits over the front turn signal housing cover stem and adapts the stem to the turn signal housing neck. Used only on these models: 1982 XJ750 Maxim front, and all XJ750 Seca front. Each:
    $ 5.95
    HCP3563SET2 OEM turn signal STAY BUSHINGS, set of 2:
    $ 10.50
    HCP3655 OEM turn signal stalk NUT, to secure the stay to the frame, frame bracket, or headlight bracket (depending on model). Fits all XJ550 models front or rear, all 1982-83 XJ650 Maxim rear, 1982 XJ650RJ Seca front or rear, and XJ650 Turbo models rear, all XJ700 models front or rear, 1983 XJ750 Maxim and Midnight Maxim rear, all XJ750 Seca rear, XJ900RK model front or rear, and all XJ1100 models front. Each:
    $ 2.50
    HCP3655SET2 OEM turn signal stalk NUTS, set of 2:
    $ 4.95
    HCP3655SET4 OEM turn signal stalk NUTS, set of 4:
    $ 9.50
    tsm2) OEM and aftermarket replacement turn signal-to-stay MOUNTING HARDWARE perfectly replaces missing, worn, or incorrect fasteners. All items work with both our original or reproduction turn signal units.
    NOTE: the CINCH BOLT and related hardware items are what attach the signal stalk or "stay" to the turn signal housing neck, thus locking the stay to the turn signal housing.
    HCP3685 OEM turn signal housing CINCH BOLT, used to secure the turn signal housing to it's mounting stem or stalk. Bright plated domed-head alloy steel bolt with a square shank under the dome head and a rounded shaft. For all XJ550 Seca front or rear, 1982 XJ750 Maxim front or rear, and XJ900RK models front or rear. Can also be used on XJ650 Turbo rear and XJ750 Seca models, but those bolts were originally provided in a black finish and a fully squared shaft. Use with the appropriate washers and nuts as listed below. Each:
    $ 6.50
    HCP3685SET2 OEM turn signal housing CINCH BOLTS, set of 2:
    $ 12.75
    HCP3685SET4 OEM turn signal housing CINCH BOLTS, set of 4:
    $ 23.95
    HCP306 OEM turn signal housing cinch bolt FLAT WASHER, used to secure the turn signal housing to it's mounting stem or stalk. Bright plated alloy steel, correct for all XJ550 Seca, 1982 XJ750 Maxim, and XJ900RK models. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 cinch bolt above. Each:
    $ 0.50
    HCP55 OEM turn signal housing cinch bolt LOCK WASHER, used to secure the turn signal housing to it's mounting stem or stalk. Bright plated alloy steel, correct for all XJ550 Seca and 1982 XJ750 Maxim models. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 cinch bolt above. Each:
    $ 0.75
    HCP913 OEM turn signal housing cinch bolt LOCK WASHER, used to secure the turn signal housing to it's mounting stem or stalk. Bright plated alloy steel, correct for all XJ550 Seca and 1982 XJ750 Maxim models. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 cinch bolt above. Each:
    $ 0.20
    HCP57 Aftermarket turn signal housing cinch bolt LOCK WASHER, used to secure the turn signal housing to it's mounting stem or stalk. Bright plated 18-8 stainless steel, correct for all XJ550 Seca and 1982 XJ750 Maxim models. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 cinch bolt above. Each:
    $ 0.25
    HCP59 Aftermarket turn signal housing cinch bolt LOCK WASHER, used to secure the turn signal housing to it's mounting stem or stalk. Black plated alloy steel is correct for all XJ650 Turbo rear and all XJ750 Seca rear signals. Use with the HCP3685 cinch bolt above. Each:
    $ 0.25
    HCP3688 OEM turn signal housing cinch bolt NUT, used to secure the turn signal housing to it's mounting stem or stalk. Black alloy steel, correct for the rear signals on all XJ650 Turbo and XJ750 Seca models. Use with the HCP3685 bolt above. Each:
    $ 0.55
    HCP3699 OEM turn signal housing cinch bolt NUT, used to secure the turn signal housing to it's mounting stem or stalk. Black alloy steel, correct for the front signals on 1982 XJ750 Maxim and all XJ750 Seca models. Use with the HCP3685 bolt above. Each:
    $ 0.95
