Headlight on XJ550 1981
Discussion in 'Hangout Lounge' started by yamamann, Oct 25, 2010.
  1. yamamann
    yamamann Member
    Barrie, Ontario, C A N A D A
    Does the headlight only come on when the engine is running ? How about the instrument lights as well ?
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Yes the headlight does come on when the engine is running. The instrument lights are on the same ciruit.
  3. zombiehouse
    zombiehouse Member
    Pomona, Ca
    I think what you really might have been asking is does the headlight only come on once the engine is running. The answer is yes. The instrument lights, such as neutral and oil, should come on when you switch on the ignition.
  4. yamamann
    yamamann Member
