Headlight wiring
Discussion in 'XJ Technical Chat' started by Austen McAllorum, Mar 2, 2023.
  1. Austen McAllorum
    Austen McAllorum New Member
    Delta,Bc,Canada
    I’m not receiving any voltage to my headlight I’m getting a power reading everywhere except for the headlight, headlight also works tested it this is leaving me puzzled I think I found where the main wiring goes but it’s just attached to this box same with the wiring to the on off switch I’m very confused any help would be lovely
  2. Franz
    Welcome to the forum. Which bike do you have?
  3. Austen McAllorum
    Delta,Bc,Canada
    Apologize I forgot to put in it’s a 650 Maxim 1980 the fuse box has been updated to blade style
  4. Franz
  5. Jetfixer
    There is a relay on the left side behind side cover , once bike is started this will open to turn headlight on . You can remove relay there are four points on the plug , if you take a piece of wire strip both ends jumper the two points on the plug and turn on key your light should come on .
  6. DarinAdkins
    DarinAdkins Member
    Dallas,TX
    Welcome to forum, which bike do you have actually? Might be battery is troubling
