hello
Discussion in 'Hangout Lounge' started by ronin, Sep 7, 2010.
  1. ronin
    ronin New Member
    hello everyone. my neighbor just gave me a 1985 maxim. the bike has not been run in 15 years. it has been in a garage and is in ok condition. so here i am looking for advice from the experts. 7k miles
    1. i am sure the bike was not stored properly so the carbs need rebuilding
    2.i put some marvel mistery oil in the pistons to help loosen things up
    3. i cannot find the key code anywhere on any locks . do i need to pull the ignition to have a key made to fit???
    4. ANY SUGGESTIONS
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Welcome
    1) You are probably right, not many people store a bike prporely for extended periods.
    2) good thing, it will help unstick rings and lube valves
    3) lock # is on the cylinder, take it to a locksmith so he can make a key.
    4) lots of things to do before a ride.
    Get a manual and read through it,
    rebuild carbs and clean tank, install a fuel filter
    change plugs and airfilter
    change all fluids
    rebuild front brakes, check rear shoes for delamination
    adjust valves
    get all lights working
    repack bearings in steering head and rear swingarm
    check wheel bearings, replace if needed
    get new tires, they may look OK but old rubber is not safe
    new battery and replace fuse block if needed
    Clean and paint parts as you are working on them
    Sync carbs
    I'm sure I missed something, you'll find it. Thats a list to get you started.
  3. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    if gonna do all that don't THINK about a new fuse box just get it for $15 and be done with it :)
  4. ronin
    ronin New Member
    where on the lock cylinder is the code # i pulled the whole thing offand i cannot find it locksmith wants 50 to rekey it. looking for cheaper way
  5. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Just get a new ignition off Ebay. I paid $25 plus shipping for the ignition on my 550 Seca.
  6. mlew
    Apex, NC
    Take the lock to a Yamaha dealer, they might be able to help. Take off the helmet lock, there should be a number on there also.
  7. seaguy
    seaguy Member
    Coastal,AL
    Take the vin number and your tag receipt to a Yamaha dealership and they can cut you a new key.
