HELP 1985 xj700n carb problem UPDATE
Discussion in 'XJ Technical Chat' started by denbola, Jun 29, 2014.
  1. denbola
    denbola Member
    poole,dorset,england
    HELP, have been chasing a fault on the 700 for some time, bike starts ok all on 4 cyls, down-pipes warms up equal and revs up clean and strong and hears the BUT as soon as you but any load ie pull away in gear or put brakes on and drag clutch it has a misfire but just give it a little choke runs ok, have ultrasonic cleaned 4 times now ,wet set 1mm (hsc33)balanced etc, have changed pilot jet from 37.5 to 43 just to test still the same so put back to 37.5,has good fuel flow from fuel tap and tested in prim position, has any-one got any ideas or any other carbs fit this model
  2. jcro61
    jcro61 Member
    Massachusetts
    Re: HELP 1985 xj700n carb problem
    are you letting it warm up completely?
  3. k-moe
    What are the pilot screws set at?
    Valves in spec?
    Checked for air leaks at the intake boots and the throttle shaft seals?
  4. Polock
    turn your mixture screws out 1/8 of a turn
  5. denbola
    denbola Member
    thanks for the reply guys, mixture screws now out to 4 turns makes no change to misfire, have sprayed wd40 on boots and shaft area with tank off, rpm did not drop or rise and valve clearance when I first got bike was ok only done 100 miles since that, was 2 years ago has been in my workshop as this xj was layed up since import in 1996 but will remove top and check again, will report back soon
  6. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I just finished my carbs and I set the floats at 2mm, within the 1mm +/- 1 in the specs. I used a colortune plug and my pilots are less than two and I'm checking the plugs and will adjust if necessary. But the bike runs great and the plugs look good at this point. My bike is pure stock. I would recheck the pilot system if you can't find any air or vacuum leaks and you are sure the floats are correct and the carbs are properly synced.
  7. denbola
    denbola Member
    just an update , now running ok, after rebuilding them 1st time replaced throttle shaft seals with no change so striped again and found main jet needle ok on cyc 1&3 but cyc 2had dropped down about 1.5mm but cyc 4 the needle had dropped by 4mm pushed home needles home to plastic stop now ok, in the past because there fixed didn't pull them out of the slides many thanks to all for there help in the past
