Help bike starts but does not stay runing
Discussion in 'XJ Technical Chat' started by Hosethe3rd, Apr 9, 2012.
  1. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    My bike starts then when it comes down to a idle it dies please help thanks
  2. hogfiddles
    Carburetors need either cleaning, or syncing......if you've already done that, go to the simple solution--
    Raise the idle. Now, how low does it get before it dies? If you play with the throttle, how low of an idle can YOU hold it at?
    Dave F
  3. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    It the choke is not working but if I play choke untill it is warm then it is fine
  4. hogfiddles
    Then it sounds like you need to take the carbs back off, pull ALL 4 of the plungers for the enriching circuit out, and clean all those passages. You also may have to pull the bowls off of the carbs and check to make sure that the pickup tube is clean all the way through, and also check to make sure that the tiny hole at the bottom of the tube well in the bowl, is clean as well.
    Do that, and then let's see ...........
    Dave F
  5. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Hey do you knoe where to get some vac gages and how di you synce them
  6. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Hdy thanks I got it running it was the idle adjustment and thanks for the starter it working great
  7. bigfitz52
    OK, good. For now.
    How many miles on it?
    The valves should have been adjusted at 3000 miles the first time and probably weren't.
    The valves were to have been adjusted at every 5000 miles thereafter. They probably weren't.
    IF THE VALVE CLEARANCES HAVE NEVER BEEN TOUCHED (highly likely:)
    and the bike has more than 8,000 miles on it, you have a bunch of tight valves, and they're getting tighter.
    If the bike has more than 13,000 miles on it, you're flirting with disaster.
    If the bike has more than 15,000 miles on it you're about to burn a valve.
    Check your valve clearances. Adjust as needed (and they will need it, trust me.)
    Then sync the carbs.
    Or ride it like it is until your next post is "bike runs fine when I first start it but it won't start hot." (That will mean you waited too long.)
    Now, then: Let's talk BRAKES: http://xjbikes.com/Forums/viewtopic/t=15874.html
  8. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    its got 39.219 and this is the 1st time since 06 so the front breaks where replaced in 05 right before the guy park it now how do i check the vales!
  9. hogfiddles
    Hey! Glad you got the starter in so quick--good work! And I'm glad the idle screw was the issue and solved!
    Now, do a lot of homework, study the forums on shim clearance checking.
    Dave Fox
  10. bigfitz52
    PLEASE READ the link I posted; it has nothing to do with the front brakes. It has to do with happens to the rear brakes on a bike that's been sitting.
    The guy probably replaced the pads; if he didn't replace the lines it's dangerous. If it's been sitting since '05 you NEED to replace the brake fluid before riding it; right now it's a disaster looking for the scene of the crash.
    This is how to check the valves: http://xjbikes.com/Forums/viewtopic/t=14827.html
    And Part Deux, additional info: http://xjbikes.com/Forums/viewtopic/t=29209.html
    If you're serious about actually using this bike; you're going to need a service manual; the sooner the better.
  11. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    I went throa that all of that has bin done other that the vales and the carbs
  12. bigfitz52
    Check the date codes on the brake lines.
  13. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    they guy I got It from said he went thou it and did the brakes so I am planing on going thou it in the fall
  14. bigfitz52
    So in the meantime you're trusting your life to "he said?"
    There are DATE CODES in the brake lines; either embossed right into the rubber or stamped into the metal ferrules at one end or the other.
    GO LOOK AT THEM. If they include the digits "80" or "81" then THEY ARE A DANGER. You wanna take a chance that one pops on you at the wrong moment?
    I don't know about you; but I didn't manage to survive 44+ years on street bikes based on what somebody "said" in regard to my equipment.
    How long does it take to LOOK at your brake lines? Is it worth your life, or a trip to the hospital?
  15. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Ill xheck them but they guy I got it from is a good friend
  16. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Thdy have bin replaced
  17. bigfitz52
    I sure hope so, as should you. If not, you're gonna find out.
    Keep something in mind about a 30-year old bike:
    You cannot get away with "shortcuts." The BIKE will not let you-- ignore something, it WILL bite you.
    You'll see.
    Meanwhile "said they were done" or not-- GO LOOK AT YOUR BRAKE LINES. If they say "05" then rest easy.
    Don't take somebody's word for it.
  18. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Yes they do thanks for rhinking of my safty I have to pay th insh before I ride it
  19. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Hey what is the rpm when it is idle
  20. bigfitz52
    1200rpm.
  21. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Ok thank it is runing really smoth at 1500rpm
  22. hogfiddles
    You'll have to find a happy medium, and it takes time to find that. Ideal is at 1100-1200 rpm. BUT on chilly days, it may idle too low so you feather the throttle a bit, on hot days it may idle a little higher, like 1300 or higher if it get's really hot. In either case, you have to learn where the 'idle screw setting is for each extreme and then set it pretty much at the middle, and get used to your bike's idiosyncracies". Hope that makes sense. I was forever playing with the idle to match conditions, but when I just set it in between the extremes, and a hair on the lower side of middle, I just learned to 'feather' the throttle as needed when it was 'too cool' out.
    Once I found that setting that I like enough, I left it there, and it stayed that way for about 9 years til I sold the bike. The current owner still has things set the same..
    You'll find it as you get a better feel for your own bike. :)
    Dave F
  23. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Thanks I will have to mess with it
