help!! carbs question
Discussion in 'XJ Technical Chat' started by toto1313, Oct 21, 2014.
  1. toto1313
    toto1313 Member
    Mexico
    Hi guys i need some help..
    Recently i change my gas tank and putted a sporster gas tank on my xj 650 82' but in the third carb there was a air-out and a hose connected to the tank. Now that i have the new oneinstalled what should i do whit that? Sorry about my bad english and thanks
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I think you are referring to the vacuum port and the connection to the petcock on the original tank. If your new tank does not have a vacuum controlled petcock then you simply cap off the vacuum port. If you can't find a cap that fits, (look at the other carb vacuum ports) you can get by by simply plugging the vacuum hose with something like a golf tee or anything that will make it air tight. That should work until you can find a cap.
  3. toto1313
    toto1313 Member
    Mexico
    Thanks very much tabaka
