Help! No spark, blowing headlight fuse
Discussion in 'XJ Technical Chat' started by vondeckerstein, May 16, 2010.
  1. vondeckerstein
    vondeckerstein New Member
    Columbia, MO
    Rebuilt my seca over the winter; painted the frame, replaced some missing exhaust studs, swapped in the front end(triple tree, forks, wheel, brakes, kept stock headlight and gauges) from an '87 honda hurricane. tore into most of the top end to inspect for damage and partly for shits and giggles. I'm ready to ride off into the sunset, except...
    I have no spark, and the headlight fuse blows every time it is replaced. the headlight is not on the bike, and if i pull the headlight relay, the low oil light comes on instead of the starter motor. I tried switching some of the relays around, it won't turn with any other relay in that position, and i think they're in the right spots.
    My brother has a wrecked '82 seca turbo(damn shame) that i can swap parts from. any ideas?
