Help please! Weak number 3, stumbles when revving.
Discussion in 'XJ Technical Chat' started by devoxide, Aug 9, 2009.
  1. devoxide
    devoxide New Member
    oslo,Norway
    Hi all
    My lovely XJ 750 (-83) is making me a pedestrian (or almost) :)
    She's loosing power when accelerating. Seems like number 3 cylinder exaust is a bit colder than the rest. I have checked the electrics and found no problem. Switched the coils from right to left without any change on number 3. The carbs has been cleaned, synced and tuned by a proffessional.
    What could be the problem?
    brgds
    Dev
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Has a compression test been done on the engine? The engine needs to be in good condition to ignite the fuel air mixture. A valve adjustment will also be necessary. If all those are in order I still would not rule out some carb issues.
  3. mlew
    Apex, NC
    Are you running the stock airbox or pod filters? What kind of exhaust system? Some jetting problems could be there.
  4. devoxide
    devoxide New Member
    oslo,Norway
    * Compression is very good (tested).
    * Stock airbox (clean filter)
    * Spark on plugs okay (plugs changed)
    * Recently (2 weeks ago) I adjusted the valve clearance on all 4. (these are okay)
    The problem of it loosing power was apparent earlier this fall, before I started doing anythin with the bike. It is slightly better now when the valves are okay and the carbs has been cleaned and synced.
    I did not do the carbs myself, could it be the emulsion tube on number 3 causing it?
    It runs nice on high rpm's, a rough on low (like it's not running on all 4) and stumbles when accellerating on about 3.500 - 4.500 rpm's (maybe higher).
  5. dqnjuan
    dqnjuan Member
    bmore, md
    hmmm sounds like possibly spark coil or something cus the charging system is stronger at the higher rpms, but def worth checking to make sure its not the carbs.
  6. devoxide
    devoxide New Member
    oslo,Norway
    I moved the left coil to the right side and vice verse. number 3 cyl was still cold compared to the other cyl's. Doesn't that rule out the coils?
    thanks
    Dev
  7. mlew
    Apex, NC
    Looks like switching the coils probably eliminated the possibility of a bad coil since the problem stayed in the #3 cylinder. I suspect a problem with the #3 carb, float level , stuck carb slide or clogged jets. The #2 and #3 cylinder share the same coil and spark advance, since the issue is only in the #3 cylinder I think it is carb related.
