Help removing light switch on 1983 XJ900
Discussion in 'XJ Technical Chat' started by tom1983, Nov 17, 2014.
  1. tom1983
    tom1983 New Member
    Latrobe pa
    Having trouble removing light switch on left handlebar on my 1983 xj900. Problem is the plastic choke portion and choke cable . Can any one help on this? Thanks
  2. hogfiddles
    Tom,
    Loosen the clutch perch and slide it forward. Loosen the control and slide IT forward. That should give you room. Disconnect the enricher cable, now you should be able to get the ring off, and open the controls.
    If you still have trouble , pm me and I'll take one of mine apart to show you
  3. tom1983
    tom1983 New Member
    Latrobe pa
    Thanks for the help, Very appreciated
  4. hogfiddles
    Did you get it apart? If your having trouble with the ring itself, you have turn it far enough around for the "tabs" to line up with the "slots", then pull straight out. Once that's out of the way, the control housing is held together by only a couple long bolts from underneath.
    Dave
