Help! Stator replacement.
Discussion in 'XJ Technical Chat' started by beardedwonder, Jul 17, 2016.
  1. beardedwonder
    beardedwonder New Member
    Decatur Alabama
    I am going to be replacing the stator on my 81 xj650 midnight maxim. I need to find a step by step instruction on how to do this. The stator went out on me yesterday. I am trying to fix it as soon as possible. I just got my bike registered on Friday. I am a new rider and new to motorcycles in general. I have been learning how to work on my bike as it has needed the repairs.
    Thank you in advance.
    Let's take a step back.
    How do you know that the stator is faulty?
  3. beardedwonder
    Decatur Alabama
    When I start the bike it will run long enough to warm up. As soon as it is warm it dies and will not start again until it cools down. I can't even get it running long enough to ride it for a minute.
    Just to make sure, I also tested my regulator rectifier with my multimeter. It check out ok.
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Are the valves in spec?
    Gary H.
  5. beardedwonder
    Decatur Alabama
    To be honest, I'm not sure what you are talking abou . I am new to working on bikes.
  6. beardedwonder
    Decatur Alabama
    The bike was running great not even 3 days ago. Then all of a sudden on Saturday morning when I tried to ride it died immediately after it warmed up.
  7. Big swede
    Big swede Active Member
    Gothenburg,Sweden
    Doesn't sound like an alternator issue....
    k-moe and beardedwonder like this.
  8. chacal
    According to the service manual, you need TWO multimeters ("pocket testers") to check the regulator/rectifier for proper operation............
    beardedwonder likes this.
  9. Yardawg
    Yardawg Active Member
    Hatch NM
    I think he may need to start from the beginning. Info overload, church of clean, etc.
    rocs82650, k-moe and beardedwonder like this.
  10. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
  11. beardedwonder
    Decatur Alabama
    I have only been abe to find a few videos on testing the stator and the regulator. I'm not 100% sure I'm doing it the correct way. My brother is the one who told me that my stator is bad. He has been riding for a long time and works on bikes. However he lives across the country. So he can only give be a diagnosis based on the same symptoms of the bike that I gave on here.
  12. beardedwonder
    Decatur Alabama
  13. beardedwonder
    Decatur Alabama
    Does it sound familiar to you?
  14. Big swede
    Gothenburg,Sweden
    It's not a bad idea to check your valve clearances as it can give these symptoms (the clearence will be tighter as the engine warm up), and make the valves to not fully close.
  15. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    First time plan on a couple hours, go slow, be meticulous (document clearances, pull every shim and record the sizes/ locations) and make sure you have a new gasket for when you put it back together. If you are extremely lucky you can do the shim dosey doh and be back up and running. If they are out of spec you should not run the bike and may need to wait several days to get the correct shims (contact Hogfiddles). And make sure you doNOT over torque the cover screws when reassembling.
  16. beardedwonder
    Decatur Alabama
    Ok, thank you very much. I will do this before spending the money on the stator.
  17. beardedwonder
    Decatur Alabama
    Thank you. I will take my time and double check/document everything. This could save me a lot of money.
  18. Yardawg
    Hatch NM
    It may be a little intimidating at first but it's really quite easy once you get going.
    Lightcs1776 and beardedwonder like this.
  19. beardedwonder
    Decatur Alabama
    That's good to know. Thank you.
    Yardawg likes this.
  20. beardedwonder
    Decatur Alabama
  21. Nuch
    Suffolk County, NY
    If you have any tools at all in your toolbox, chances are you have some already. If you don't, the good news is that Harbor Freight has inexpensive sets of things that for general wrenching around your bike, they will last forever...
    Metric Box Wrench Set (nine bucks!)You'll need the 19mm for turning the crankshaft:
    http://www.harborfreight.com/9-piece-metric-highly-polished-combo-wrench-set-42305.html
    Hex Drive Set: (15 bucks!) Not sure which on off the top of my head to remove cover bolts... but it's in this set:
    http://www.harborfreight.com/9-piece-38-and-12-drive-metric-hex-bit-socket-set-67880.html
    and/or
    Hex Ket Set (nine bucks!)... for the hard to reach bolts... you'll need the metric ones:
    http://www.harborfreight.com/36-piece-sae-metric-hex-key-set-94725.html
    Metric Feeler Gauge Set (fifteen bucks!) Item [HCP6383]
    http://www.xjbikes.com/forums/threads/xj-parts-catalog-section-p-the-toolbox.44630/
    A pair of forceps (tweezers, or hemostats, or magnet on a stick, etc...) to pull shims out.
    A small flat screwdriver to pop shims from their buckets.
    And In my opinion, zip ties for the zip tie method of holding the valve open for pulling the shims... But that's a whole other discussion.
  22. k-moe
    Or a single strand of insulated 12 gauge copper house wire, one foot long.
  23. chacal
    Nice drawing!
    Jetfixer likes this.
  24. k-moe
    I practiced a lot in 3rd grade :p
  25. beardedwonder
    Decatur Alabama
    Thank you both! This seems much less intimidating, knowing what exact tools are needed. I will share my progress after I have been able to work on my bike again. This forum has been extremely helpful!
  26. Nuch
    Suffolk County, NY
    I like the detail on the threaded spark plug hole and from the looks of it you even used a piece of wire that has "experience" in doing the job!
  27. beardedwonder
    Decatur Alabama
    Ok, so I just found out that I have been using the wrong gas in my bike. I have been using regular gas (87 octane) instead of premium gas (93 octane). I found d out that I am suppose to use no less than 91 octane. Could that be part of my problem? Even though I have been running it with regular this entire time?
  28. rocs82650
    Middle Tennessee
    Says who?
    Gary H.
  29. beardedwonder
    Decatur Alabama
    It's says it on a label in the side cover on the side with the rectifier.
  30. k-moe
    There are several methods for determining octane. The U.S. is the oddball (imagine that) in averaging two of the methods to arrive at pump octane. You have been using the correct fuel all along.
    rocs82650 likes this.
  31. k-moe
    When your XJ was made the octane rating was given using the MON standard, which is why it has a higher number than you'll see at the pump for the same octane of fuel (now given as (RON + MON) /2 in the U.S.).
  32. beardedwonder
    Decatur Alabama
    Awesome! Thank you for the info.
  33. rocs82650
    Middle Tennessee
    Add a double shot of Seafoam after everything other full up and your bike will be fine fuel wise.
    Gary H.
  34. k-moe
    He'll be fine fuel wise even without the Seafoam, toough it won't hurt to use it.
  35. rocs82650
    Middle Tennessee
    Agreed. I just add it for good measure.
    Gary H.
  36. beardedwonder
    Decatur Alabama
    I decided to start the bike one last time before I took it apart. Just to see what happens. It started and was smoking a light grey smoke. I'm not 100% sure. As I am partially color blind. It was smoking really bad for a while. I was able to keep the bike running long enough to try and ride it for a minute after adjusting the idle. I brought it back in the garage and shut it off. After that it would not start again.
    Does this give anymore insight and confirmation that it is a problem with the valves?
  37. rocs82650
    Middle Tennessee
  38. beardedwonder
    Decatur Alabama
    Thank you. That is all I needed to know.
  39. DrewUth
    DrewUth Active Member
    South Jersey
    GUYS- it warms up, dies, and then starts again when cool. That's exactly what ignition coils do when they fail, no? Agreed, it could also be tight valves.
  40. Big swede
    Gothenburg,Sweden
    Can be, but unlikely both at the same time, check if you have spark next time it happens. Did you check your clearences?
  41. beardedwonder
    Decatur Alabama
    I do get spark on all the plugs. I have not had time to check the clearence yet. I work second shift and I work 12 hours a day right now. So it won't be until the weekend when I can work on it.
  42. jayrodoh
    jayrodoh YimYam
    Cleveland
    Shims in 3rd grade? Nice!
  43. Jetfixer
    Ok read all this.. started out "bad stator" Start over.. what condition is your BATTERY in ? is the level correct ? serviced with distilled water? How do your battery lead look any corrosion? Check lead at starter too . The Solenoid might have corrosion as well, starter button wiring, Is your fuse block still original or has it been upgraded to blade type fuses. ALL of these things could be a problem, I do agree checking valves is a priority, as well as cleaning carbs , but one problem at a time .
  44. k-moe
    It's not the stator.
    DrewUth and Jetfixer like this.
  45. Big swede
    Gothenburg,Sweden
    Are you sure? ;)
  46. k-moe
    The bike starts again when it cools down. If the stator were faulty the bike would run until the battery was drawn down too far to be able to re-start without bump-starting.
    Stator stops puting out pixies, the bike runs on what pixies have been resting in the battery, until they are all pooped out.
    So yes, I'm sure.
    Stumplifter, DrewUth and Big swede like this.
  47. Jetfixer
    I agree , but he does not give enough info of what he has done ,or not...
  48. hogfiddles
    If you multimeter is telling the r/r is ok, how are you determining that?
    If it's by steady voltage at about 14.5v or so, your stator is fine. If it is only at battery level and dropping, then it starts to point that way, but other things can still be the issue....
    Sounds more like TCI symptoms at a quick glance
  49. beardedwonder
    Decatur Alabama
    I have replace the fuse box and all the controls. The battery is still pretty new. And I took it and got it refilled with acid, charged up at the store and then it was tested to make sure it was good. The battery stays at 13.19 volts at rest. But jumps up to 14 volts when I try and start the bike.
  50. beardedwonder
    Decatur Alabama
    I did a continuity test on all the white wire connections. They all measured the same. And then did the same thing for the, what I think are green wires. And they also all measured the same.
