Help With Dyna Coil Install
Discussion in 'XJ Technical Chat' started by bluemoonz, Apr 21, 2012.
  1. bluemoonz
    bluemoonz New Member
    Colorado
  2. Dannymax
    Dannymax Member
    East central NY
    Nice job...I'm waiting for boots & connectors to complete the Dyna install.
    What are you running for plugs....gap?
  3. bluemoonz
    Colorado
    NGK plugs for now. I stopped by the cycle shop and picked up some NGK Boots that are hard plastic. I grabbed a mix of straight and 45 degrees till I see what will lay out the best. I grabbed the coil terminals and boots off of amazon. Have not had time to put them on yet. I'm uncertain of what the gap is. I'll have to consult my shop manual. I figured I'd measure the old ones in the bike at the time I pull them.
  4. Dannymax
    Dannymax Member
    East central NY
    I decided to try NGK Iridium DR8EIX plugs gapped @ .040" & 8 mm copper core wire w/oem converted T-140 plug caps.
