Help with xj 650 '82
Discussion in 'XJ Technical Chat' started by toto1313, Mar 26, 2013.
  1. toto1313
    toto1313 Member
    Mexico
    Hi everyone, im new in this forum and this is my first post and i need some help with my bike(i dont know if i posting in the right topic)...
    My bike is a xj 650 '82 im start a project with my baby. I want to make a bobber, the last week i change the air filter, for 4 individualy filters, but now its seems my bike its gaining too much air cause the new filters. Aproximately how much screw turns(from clompetely closed) i have to open the air,(how much screw turns you have your bikes) hope you can help me
    PD: sorry about my bad english.... thanks
  2. 750E-II_29Rbloke
    South Cheshire, UK
    Lots of debate on pod filters, do a quick search using "PODS" or "running pods" or similar as a search term (the "SIMPLE MOD MAY SOLVE POD TUNING...." thread is worth a look, it's a bit of a train wreck but lots of info if you pick thru it).
    general concencus is to avoid them if you have the airbox to put back in. if you MUST use pods then you need to do more than adjust screws, like change to bigger jets & run velocity stacks (the original airbox rubbers are thought best by those who know)
    The pilot screws are just that, they adjust the pilot/idle mixture & not much else (that is over-simplifying it, but all that matters in this case for now)...
    Welcome. Hope you stick with the airbox, you'll find it a lot easier to keep the bike running smoothly & the pistons hole-free lol :?
  3. toto1313
    toto1313 Member
    Mexico
    well thanks for the advice Rbloke :(
  4. 750E-II_29Rbloke
    South Cheshire, UK
    Don't get too disheartened, like I said just search about a bit, it's not IMPOSSIBLE just hard work to get running good on pods & I don't want you to hurt your engine as it seems you're already running very lean. If I can tell you the facts without sugar-coating it, it might save you an engine ;)
    Like I say, some people have found using the original airbox rubbers to mount the pods on can help smooth the airflow but you probably will need to up-jet as well to save your engine from burning a piston or four...
  5. toto1313
    toto1313 Member
    Mexico
    ok ok thanks dude i understan :p..i discard the airbox then i need to get one XD
  6. 750E-II_29Rbloke
    South Cheshire, UK
    Oh no, is there no way you can get it back? :( I really wouldn't advise riding without it if the bike feels like it's running lean (these engines can feel like they run just fine yet still be dangerously lean, so if it *feels* lean too, chances are it's really in the "red-zone" as far as piston temperatures go).
    There's some 650's being parted out in the sell/trade/swap area, and if somebody else could confirm, I think the 750 airbox may work too?
  7. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Toto, eres de Mexico? De que parte, yo estoy restaurando una 650 seca
  8. toto1313
    toto1313 Member
    Mexico
    asi es :) de mexicali BC y tu
  9. 750E-II_29Rbloke
    South Cheshire, UK
    Has encontrado un amigo que hable su idioma! Trato de usar traductor Google, tal vez va a funcionar ...
    Hope that made some sort of sense, otherwise google-translate has a lot to answer for lol!
    Eco, do you know if 650/750 airbox is the same?
  10. toto1313
    toto1313 Member
    Mexico
    i dont know bro, maybe yes maybe is the same airbox im gona look in junk yards
  11. 750E-II_29Rbloke
    South Cheshire, UK
    Was asking "Eco" (Ecologito I meant, just realised I said echo :oops: ) if he knows, would be easier for you to find a replacement if they are the same...
    Sorry to get off track, but have either of you seen the film "vanishing point"? I think I just figured out what the old desert scavenger guy shouts after Kowalski as he drives off. Just figured it'd be something like stay alive or stop or similar, stop alive comes out of google translate as dejar con vida, that kinda sounds like what he says or maybe "mantenerse con vida", ¿sabe usted? (yes I love how the language sounds, wish I could learn!)
  12. ecologito
    NASCAR Country, NC
    toto, que modelo de es tu 650? seca, maxim?
  13. toto1313
    toto1313 Member
    Mexico
    es una maxim
  14. chacal
    Modelo 650 y modelo 750 "airboxeo" no es similar........
    How'd I do?
  15. 750E-II_29Rbloke
    South Cheshire, UK
