HELP
Discussion in 'XJ Technical Chat' started by haro3483, Jul 8, 2011.
  1. haro3483
    haro3483 New Member
    Carman Manitoba
    So I just cleaned my carbs, checked the valves, they are in spec, synced and tuned, The only way it will start is if I boost it, Battery wont stay charged and its a brand new battery, So when the bike is running It runs good but when i start to go anywhere it cuts in and out, bogs real hard, Lights dim and then go brighter then dim again, anyways I was wondering if someone had an idea where to start, ive checked the fuses and wires, sorry for the dumb question, still new to working on my own bikes Bike is a 1982 xj 1100
  2. bigfitz52
    Alternator, brushes/wiring; connections at regulator/rectifier; fusebox.
  3. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Load test the battery? I recently picked up a new battery that was junk
  4. haro3483
    haro3483 New Member
    Carman Manitoba
    Ive never checked the alternator on a bike before, Easy hard ? ?
  5. bigfitz52
    Easy but you need a manual before you go much further.
  6. haro3483
    haro3483 New Member
    Carman Manitoba
    UPDATE- Altenator rebuilt, Bike wont start and is still giving me that bog and its cutting out, The only way i can start it is if I boost it, Once started the bike will sit there and idle but will kinda run like sh**, Once I turn the bike off I cant start it again, It will sit there and make a clicking noise, Any Ideas what I should be checking next? Thanks guys
  7. MaximumX
    MaximumX Member
    Ottawa, Canada
    Have you tested the battery itself?
  8. haro3483
    haro3483 New Member
    Carman Manitoba
    Yes the battery is brand new and it checks out good
  9. bigfitz52
    Do you have a manual yet? You're going to need to troubleshoot the regulator/rectifier and associated wiring.
  10. haro3483
    haro3483 New Member
    Carman Manitoba
    Yep, I found the problem, It was a broken wire in the headlight case shorting out, She runs like a champ now, thanks for all the help
