help!!
Discussion in 'XJ Technical Chat' started by toto1313, Mar 23, 2014.
  1. toto1313
    toto1313 Member
    Mexico
    Hi guys
    I need some help i was washing my bike (xj 650 82' maxim)
    And i disconnected the spark plug wires and i dont know
    The order, somebody can helpme please... And thanks
  2. lacucaracha
    lacucaracha Member
    Napa, CA
    + is toward the back of the bike, - toward the front. The writes are not really long enough to switch though, so I don't see how you could, and they definitely won't reach if the battery is installed backwards.
    Just look at it. There's only one possible way it makes any sense.
  3. toto1313
    toto1313 Member
    Mexico
    Thanks lacucaracha . The problem is my bike is
    Modified so the wires can be plug in any spark plug sorry
    For my bad english
  4. lacucaracha
    lacucaracha Member
    Napa, CA
    oh, sorry. I thought you were talking about the battery.
    In that case the spark plug wires should be in order from left to right, mirroring how they come out of the coils
    If you have aftermarket coils, I do not know the front to back order on the coil itself and how it is supposed to relate to the actual plugs.
  5. toto1313
    toto1313 Member
    Mexico
    No. I have the originals ignition coils. Iwas searching and i
    Found a page where it says the left coil is for 3-2 spark plug and the
    Right coil is for 4-1 sparks plug
  6. lacucaracha
    lacucaracha Member
    Napa, CA
    That is correct. They both spark at the same time, so there is no issue if they are mixed up on the correct side.
  7. lacucaracha
    lacucaracha Member
    Napa, CA
    (I think, but someone should back me up on that.)
  8. toto1313
    toto1313 Member
    Mexico
    I foun another topic in here(xjbikes) and its seems is correct ledt coil
    Is for 3-2 and the right one is for 4-1(in that orderr)
    But another guy said that is 2-3 and 1-4 i dont know
    Who is correct. I dont know if i can change the 1 for th 4
    ,and the 2 for the 3 . I
  9. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    Yup, the left coil sparks 1 and 4, right coil sparks 2 and 3. Each coil will fire both wires at the same time, so it doesn't matter which goes where, as long as 1 and 4 lead to the left coil.
  10. PilotSmack
    Calgary, Canada
    You type faster than I do. 1 and 4 are interchangeable, as is 2 and 3.
  11. toto1313
    toto1313 Member
    Mexico
    Thanks pilotsmack. I have another question i hope
    You can helpme too. Both coils are exactly the same
    But one has write the number "107" and the other has "108"
    Is that normal?
  12. toto1313
    toto1313 Member
    Mexico
    And the coil's socket can be plug in any of the
    Two coils?
  13. PilotSmack
    Calgary, Canada
    Yup those numbers are normal. They are just different part numbers.
    Not sure what you mean by the coil's socket... you mean it's connector that comes from the TCI box? Those ones are specific for the left or right coil. I don't have a wiring diagram but I'll look it up for you in a little bit unless someone else answers.
  14. toto1313
    toto1313 Member
    Mexico
    Yep dude i mean that c onectors from the tci box .
    Thanks very much
  15. toto1313
    toto1313 Member
    Mexico
    I got it dude. One coil has red and orange and the other
    Has gray and red . And the wires from the tci too has red and orange
    And gray and red
  16. toto1313
    toto1313 Member
    Mexico
    Thanks a lot you both i learned something more from
    My bike today thanks again
  17. PilotSmack
    Calgary, Canada
    Just match em up... red-orange to red-orange, red-grey to red-grey.
  18. PilotSmack
    Calgary, Canada
    No worries. Cheers!
