higher speed gauge?
Discussion in 'XJ DIY How-To Instructions' started by darren ditmar, Jan 13, 2015.
  1. darren ditmar
    darren ditmar Member
    eugene oregon
    82 xj550 any suggestions the 80mph limit just isnt cutting it
  2. dizzycow
    dizzycow Member
    Huntsville, AL
    I asked about this in another thread and someone told me that it's hard to do because the speedo is geared to go up to 80mph so there would be some serious modification involved to get the same speed to go up to whatever the top speed is. May i suggest getting a bicycle speedometer and strapping it to the handle bars.
  3. darren ditmar
    eugene oregon
    i had not thought of that lol i have one i will try and see if it doesnt fly off
    it will only get me another 10mph though
    :cool:
    dizzycow likes this.
  5. k-moe
    Most bicycle speedometers will accurately display up to 200 MPH.
  6. darren ditmar
    eugene oregon
    my one says it only goes to 100
  7. FtUp
    FtUp Well-Known Member
    pacific northwest
    another possibility is to have a ratio adapter installed in the speedo cable. I just spoke to a guy at west valley instruments in cali that said he could install one in my cable for less than $100 if I send him a cable. that would make our 80mph speedos 130mph speedos. probably the easiest way to get around the 80mph limitation.
    in case anyone is interested in talking to the guy at west valley instruments, here is the number. 818 758 9500
    FU
  8. k-moe
    What does he charge for a new faceplate to go with the correction gearbox?
  9. FtUp
    pacific northwest
    dunno, I didn't ask. but considering the work they do, they could probably do it. you might want to contact them yourself.
    http://westvalleyinstruments.com/
    FU
  10. k-moe
    Thanks for the info.
  11. 4nik8r
    4nik8r Active Member
    Ottawa, ON, Canada
    I have a Canadian one that is in good mechanical shape and properly geared to 220 kph (140 mph), but it reads kph as the primary (outside) and miles as the minor (inside). It would work for you, but you would want to use your existing needle and perhaps (optional) source that faceplate.
    Let me know if you are interested in it.
  12. Polock
    it's been awhile since i had a analog speedo but isn't there a pin that stops the needle? snip it off.
    and a bicycle speedo doesn't have a light in it :(
  13. k-moe
    The stop is there to keep the speedometer from damaging the very fine spring that controls the accuracy of the speedometer. I don't know which bicycle speedometers y'all are using, but my $11 Bell reads to 200 MPH (bench tested) and has a backlight. I'd shop around to find one with that functionality.
