Hitachi Jets plugged
Discussion in 'XJ Technical Chat' started by Gmtec2, Sep 23, 2014.
  1. Gmtec2
    Gmtec2 New Member
    Dyer,IN
    Newbie here but have had some experience with carbs. I just acquired a 85 Maxim 700 that has been sitting for 12 years. I pulled the bowls and found jets plugged. I've tried soaking in carb cleaner, sea foam, and boiling in water. The orafice so small I don't want to try to push anything through causing damage. Any tricks to getting these things cleaned up?
    I'm also looking for some carb gaskets and a float needle. I see there is a vendor on the site, but don't see how I can order from them.
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Send a message to user name chacal. He will get you everything you need.
  3. Rooster53
    +1 on Chacal, he will get you fixed up, you can email him at info@xj4ever.com .
    Don't remember where I read it, but someone on here made the suggestion of using one of the bristles from a parts cleaning brush. They are small enough even for the pilot jet. And yes, using any kind of metal to push through is a bad idea.
  4. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Soak them in carb cleaner for 24hours, then blast them out with compressed air. Even the little cans of air for cleaning a keyboard will help. Unfortunately the modern chemicals they use in carb cleaner aren't what they used to be, so they have to soak longer. I also soaked mine in an ultrasonic cleaner,malthough I was later told that carb cleaner in an sonic bath is a good way to start a fire. It worked for cleaning, though.
  5. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Try Chemtool B12 cleaner.
  6. k-moe
  7. Polock
    steel guitar strings or just buy new jets, their cheap
  8. Gmtec2
    Gmtec2 New Member
    Dyer,IN
    I had soaked them overnight and blew them out with compressed air. Thanks for the help!
