Home made synchronizer /manometer for four cylinder bikes
Discussion in 'For Sale, Trade/Swap, Wanted' started by jamcam1999, Mar 31, 2010.
  1. jamcam1999
    jamcam1999 Member
    <a href="http://maps.google.com/maps?q=50.064192+-
    Does anyone have pictures, measurements and specifications for a four cylinder home made manometer/carb synchronizer? I want to build one but not sure of the tubing lengths and how much oil/fluid to put into the tubes.
  2. Hillsy
    Hillsy Member
    You can use the single tube / 2 cyl one and just balance the 2 banks of carbs separately. It's far easier to make the single one and there is less room for "leaks" from multiple joins that will drive you mad trying to balance the 4 carbs at once.
  3. davstarks
    davstarks Member
    Grayling MI
  4. xj_crazy
    xj_crazy Member
    good chance of sucking tranyfluid into the motor with that sync tool but good luck with it
  5. TIMEtoRIDE
  6. davstarks
    davstarks Member
    Grayling MI
    If tyou bench sync first, it will be close enough that it shouldn't suck the oil thru. But use 2 cycle engine oil and it won't hurt anything if it does go thru.
  7. Hillsy
    Hillsy Member
    Re: Home made synchronizer /manometer for four cylinder bike
    +1 - I've used the single tube version for years now and have never had the oil sucked into the motor. I've got about 12 feet of tube all up, so there's a fair bit of room to adjust if it's way out :wink:
  8. gregu
    gregu Member
    Solvang, CA
    Guys...I used a 4 dial vacuum gauge set to sync but the gauges were bouncing around alot. I'd like to try the 4 tube manometer.
    The link shows a single stick, 2 carb manometer. Is there a link out there to a four carb manometer?
    Secondly, the YCIS shutoff tool is still a necessary component to the test, correct?
    Thanks, Greg
  9. c21aakevin
    c21aakevin Member
    Macomb, MI
  10. davstarks
    davstarks Member
    Grayling MI
  11. gregu
    gregu Member
    Solvang, CA
    I borrowed a home built YICS tool once and it worked well...time to build my own. Thanks for the links.
  12. yamchop
    yamchop Member
    Caldwell, Idaho
    I just made a four tube manometer using four 10' sections of 1/4" tube and four 1/4" sprinkler drip system tees. Put it all together, make sure each tube is the same length, seal up the open ends of the end tees with a hot glue gun, and add atf. To keep it all together and organized I taped it to a 2x4 and hung it from the ceiling. Worked great. Bench sync first and you won't suck any atf into your engine.
