Home Made YICS Tool Diagrams
Discussion in 'XJ DIY How-To Instructions' started by Matt Rolls, Sep 25, 2015.
  1. Matt Rolls
    Matt Rolls New Member
    UK
    Afternoon lads and lasses;
    Following a bunch of crappy sketches of YICS blanking tools in imperial sizes, I decided to whip up a YICS tool assembly in CAD and draft it. Attached is a PDF (warning it is A1 size paper for a 1:1 print) and below is a large JPEG. Why blow the bank on an official tool when you can make your own?
  2. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Seweeeet! You could not have made this clearer. I've been reading the YICS tool vs no YICS tool for months, and now I don't have to decide. Plus, I get to make a tool! Bonus.
    Ray likes this.
  3. XJ550H
    you should see if they will add it to info overload with the link to the YICS diagram for us non metric folks
  4. Matt Rolls
    UK
    I can fairly easily annotate this in suitable imperial sizes if you would like? Although, it doesn't do my brain any good specifying components in imperial sizes for a bike that is entirely metric...
    I think I forgot to mention when I posted it originally - there are parts where the diameters are arbitrary. For instance, the copper pipe; so long as it fits on the threaded bar and also fits down the YICS passage, the outer diameter doesn't matter - just so long as it allows the wingnut to compress the rubber to block off the YICS ports. Same with the Penny Washer, just as long as its larger than the YICS bolt head.
  5. MattiThundrrr
    So does anybody know offhand what the diameter of YICS tube? It would be awesome if we could have all the info required to build this tool in one thread.
  6. Matt Rolls
    UK
    I can measure this tonight - will post later/tomorrow. I'll get to work on an imperial version. Will also design a complete YICS delete device (one that has viton o-rings and can be fixed into the YICS passage permanently & won't melt).
    Ray likes this.
  7. Matt Rolls
    UK
    For non-metric folks, here's a new drawing with the imperial sizes in parenthesis.
    Rusty81, 45RidingAn85 and Ray like this.
  8. XJ550H
    it realy does not matter if the hardware is metric or imperial . when the tool is tightened the tubing is expanded.
    metric hardware is costly compared to standard for me to purcahse
    Ray likes this.
  9. chacal
    At My Computer
    Viton will melt like butter when used inside the YICS chamber.
  10. Polock
    Viton will do 400F, PTFE (Teflon) can do 500F.
    but i think you'd be better off forgetting about the whole thing
  11. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    if you really want to close off the YICS, strips of cotton t-shirts soaked in oil and stuffed tightly in the YICS and closed off with the bolts..
  12. Matt Rolls
    UK
    Of course it will, having a look last night I realised the YICS passage is a very high temperature environment. Maybe permanent YICS blanking is a bad idea without some really special sealing material, but I do need to balance the carbs.
    Also;
    I apologise if I came across as flippant - I more meant that imperial is hard for me to work with as I am almost totally unfamiliar with sizings and conversions for metric. The most interaction I have with imperial fixings is when I find one on a car or bike and start shouting and throwing things because I don't have the correct socket/nut/wrench etc. I didn't even know when I produced the latest drawing that imperial threaded rod has a # value plus a threads per inch value for the pitch, I had to learn what it all means!
  13. XJ550H
    I did not take it that way, I should have said the only size critical parts are the tubing and the placement of the tubing. metric hardware is is costly here.
    I liked the drawings ,
    metric is not understood that well in US.
  14. Polock
    what time is it in metric.....hummm ?
  15. k-moe
  16. MattiThundrrr
    I guess if landing on the moon is more important to you than making a decent motorbike...;) And also, when was the last time that happened? When imperial still made sense?
    PS Wasn't the moon landing a hoax directed by Stanley Kubrick?:Blackalien
  17. Matt Rolls
    UK
    I can see this debate going downhill rapidly. Can we use the metric system to land an imperial YICS blanking tool on the moon? :eek:
    Also; as a side note as there are some heavy hitters here in this thread - Has anybody had any trouble fitting A2 or A4 grade stainless steel fixings to the 58L or 4BB motors?
    By that I mean, has anyone had any issues after an engine dress-up with stainless fixings and galvanic corrosion? I have put together a full set of screws to replace all of the fixings for the clutch cover, gearbox cover, generator, carbs & starter because the previous owner has mashed up every JIS head screw and allen-key caphead in sight, and they're half painted and crusty.
    Possibly related to that question, should I use semi permanent threadlock on the engine casing screws (gearbox cover, clutch cover, generator cap, starter etc)? Or can I possibly combat the corrosion with anti-seize, or will that just make the screws vibrate themselves out?
  18. XJ550H
  19. Matt Rolls
    UK
    Ah excellent - I've just completed an engine rebuild and replaced all the fasteners with A4 stainless ones, with Torx heads instead of those nasty JIS screws. I coated them all in a non-setting high temperature thread lock after chasing all the threads out with a plug tap, so hopefully they won't seize.
    I was going to use the YICS tool to do a the first carb sync but then it started idling/running really well a couple weeks ago. They say not to fix that isn't broken...
  20. Mustang
    Mustang Member
    Masonville
    What's the best rubber tubing to use for this
