How different are the bikes between 1980-82?
Discussion in 'XJ Technical Chat' started by bobbytheblack, Aug 4, 2011.
  1. bobbytheblack
    bobbytheblack Member
    Seattle, WA
  2. MiCarl
    The 80-81 service manual is correct EXCEPT where the information is superseded by the supplement. The factory book for the 82-83 is the 80-81 with the supplement stuck in front.
    They way you use it is to start with the supplement. If it's not covered there go to the 80-81 manual.
    If I recall correctly (manual is in the shop) the supplement covers:
    - Side stand safety circuit (new in 82) and new wiring diagrams and test procedures.
    - Tells you that the 82+ cam chain tensioner is automatic so to disregard servicing it.
    - Air assist forks (new in 82).
    - Additional tool required for carburetor synchronization (YICS new in 82).
  3. chacal
    Don't forget the electric tacho for the 1982-up models.........!
  4. MiCarl
    :oops:
  5. bobbytheblack
    Seattle, WA
    But to do basic maintenance I have all the books I need
    I also have the the Haynes book...
  6. bigfitz52
    I gotta say I'm pretty impressed by Haynes' section on carbs; way better than the factory book in that area.
