How do I get this off?
Discussion in 'XJ Technical Chat' started by alaskazzr, Jul 22, 2008.
  1. alaskazzr
    alaskazzr Member
    Anchorage Alaska
    Hi all,
    I'm trying to get down to the point where I can really take a peek at the transmission components on the bike. Right now my work stoppage is on this 30mm nut inside the clutch basket. I attached a pic for reference. Is there a trick to getting it out? I have it in a gear (1st i think :/), and i have a board through the back wheel as to keep it from moving.
    So how do I get this rascal off?
    8' breaker bar? : :twisted:
  2. wizard
    manual says, lock the transmission, straighten the tab washer & unscrew the nut, you seem to have done most of this, so it's just tight, take 2 wheetabix & try again. Wiz.
  3. alaskazzr
    alaskazzr Member
    Anchorage Alaska
    lol ok...just making sure it wasn't reverse threaded or something.
    Thanks.
  4. chacal
    Wheetabix?
  5. wizard
    supposed to make you grow big & strong!
  6. KAOS
    KAOS Member
    Newport, Maine
    ROFLMAO!! :lol:
  7. wizard
    try some
  8. treybaxter
    treybaxter Member
    Mississippi
    Man, I need to move down under, they got buiscuits in their cereal? Sausage in there too?
    lol...
    Gotta be better than Grape Nuts here.
  9. biggmeany2000
    biggmeany2000 Member
    Moorefield, West Virginia
    Yeah! Here in the states we have Wheaties or you could eat your Cheereos! :D
  10. mlew
    mlew Well-Known Member
    Apex, NC
    Air inpact wrench will get it right off. Then sit back and enjoy a candy bar and admire your work. To heck with the health food.
  11. TIMEtoRIDE
    You can buy Weetabix at grocers that have a "British" section
    Tastes like Kelloggs corn flakes, but pressed into a biscuit.
  12. mrkil
    mrkil Member
    Toronto ont.
    weetabix is regular cereal here in the great white north
  13. gitbox
    gitbox Member
    If you can't find a 30mm socket in your town (like me), a 1-3/16" socket will fit it fine.
  14. acergremlin
    acergremlin Member
    NE UK
    cheap way to lock the inner clutch basket is to use 2 old clutch plates, a steel one and one with the friction material on it, drill and bolt these together and it will lock the inner basket. Then all you need is that extra weetabix to get the bitch off.
  15. MrShake
    MrShake Member
    Normal, IL
    +1 on air impact wrench... came right off on mine. My service manual also talks about a clutch holder tool that allows you to stop the basek from turning.
  16. bigfitz52
    Clutch holder tool is a single plate with both outside 'tangs' and inside 'teeth' on the same piece, with a handle. If you have the old plates and have no more use, then screwing two together makes a great "holding tool."
