How do you get the alternator rotor off.... [xj 750]
Discussion in 'XJ Technical Chat' started by frankenbike, Mar 27, 2009.
  1. frankenbike
    frankenbike New Member
    michigan
    I have to pull the alternator rotor off my ’82 XJ 750 Seca. I got the center bolt out, & it looks like some yama-tool threads in there & pops the rotor off.
    Is there a DIY tool that you’ all use or make up that does the job?
    Thnx
  2. bill
    bill Active Member
    Raleigh, NC
    I don't have the size but an appropriately sized bolt is threaded in and pushes the rotor off. A search should yield the size.
  3. Robert
    You need a M-16 (15.80mm dia.) x 1.50 pitch. at least 35mm long.
  4. frankenbike
    michigan
    Here's what I ended up doing:
    Got a bolt from a harbor freight "large" bearing puller [turned out to be a M-16 (15.80mm dia.) x 1.50 pitch], a 1.5-2" long section of garde 5 3/8 bolt shaft, with the head cut off.
    dropped the grade 5 bolt into the alt shaft hole, screwed in the HF bearing puller bolt, tightened it up till the rotor popped off.
    thanx guys.
